20 Most Recent
Advance CONNECTs HP Pavilion TX2117 AC Power Supply (HP09PAVILIONTX2117791) Questions & Answers
I need to reinstall the webcam on my hp pavilion
I recommend try to reinstall the Operating System to make it more easier to isolate if its a hardware or software problem and after you reinstall the Operating System and you are getting same error message it means the problem is already with the hardware, if its a problem with the hardware better to call the manufacturer to have the machine service or go to any local computer center and let them service your machine.
I have just noticed on my CC invoice that I have been billed for Amazon UK Prime when I only purchased two Christmas presents for my Lady in Kent.
I did not understand this was to be ongoing charge
It sounds like you may have accidentally signed up for an Amazon UK Prime subscription. Prime memberships typically renew automatically on a monthly or yearly basis, which could explain the ongoing charge on your credit card.
Regarding the multiple credit cards on your account, it's possible that you have added multiple cards for different purposes, such as for easier and more secure payment options. If you're unsure about the purpose of each card, I would recommend contacting Amazon's customer service for clarification.
If you did not intend to sign up for Prime, you can easily cancel your subscription by going to your Amazon account settings and selecting "End membership." You can also choose to end automatic renewals to avoid future charges.
As for the multiple credit cards on your account, you can remove any that you no longer need by going to your payment settings and selecting "Edit" or "Delete" next to the card you wish to remove.
12/25/2023 6:07:58 AM •
Advance...
Answered
on Dec 25, 2023
My DC35 charges fine and works fine until I press the Max button then it cuts out after about 20 secs. Do I need a new battery or is it something else? Thanks in advance for any advice before spending out money. From Leigh
The issue with your Dyson DC35 cutting out after 20 seconds after pressing the "Max" button could be caused by several things, including a problem with the battery, the charging system, or the vacuum itself. Here are a few things you can try before replacing the battery or any other parts:
- Check the battery connection: Make sure the battery is securely connected to the vacuum.
- Clean the battery contacts: Dirt and debris can build up on the battery contacts, which can affect the battery's performance. Clean the contacts with a soft cloth.
- Charge the battery: If the battery is not fully charged, it could be the reason why the vacuum cuts out after 20 seconds. Charge the battery fully and try it again.
- Reset the vacuum: If the vacuum has a reset button, try pressing it to reset the system.
- Check for blockages: If the vacuum has any blockages in the hose, brush roll, or other parts, it can affect its performance. Check for blockages and remove them if necessary.
If the issue persists after trying these steps, it may be a more serious problem with the vacuum that requires professional repair. Before spending money on a new battery or parts, it's best to consult with a Dyson repair professional to diagnose the problem and determine the best course of action
12/25/2023 6:02:42 AM •
Advance...
Answered
on Dec 25, 2023
My BLU Advance 4.0 L is not coming on. When plugged into the charger the battery icon with the lighting bolt is just blinking on and off. How can I fix this?
A blinking battery icon with a lightning bolt usually indicates a battery charging issue. To resolve this, you can try the following steps:
- Use a different charging cable and adapter to see if the cable or adapter is the problem.
- Perform a soft reset by holding the power button for 30 seconds.
- If the phone is still not charging, try charging it with a different power source.
- Clean the charging port and check if there is any debris or damage.
- If none of the above steps work, it could be a hardware issue, in which case you should contact BLU or a professional repair service.
Note: These are general steps and may not be specific to your device, please refer to the user manual for more specific instructions.
1/31/2023 2:06:52 PM •
Advance...
Answered
on Jan 31, 2023
EOC2611P. Why can't I log in after resetting two units?
Exactly the same thing happened to mine a couple of days ago as well. Reset to Factory defaults and then not able to login with default username and password.
I have mine working again now, but I had to reinstall the firmware for a different model.
Instructions can files can be found here. Read the file "Update Firmware via Telnet for EOC-1650.pdf"
http://150.242.128.185/engenius/EOL/EOC1650/Firmware%20Recovery%20Procedure/
Once I had it working I tried to upgrade to the latest firmware for the EOC2611P, but that did not work so went back to EOC1650 firmware.
I have been using the box all day with the EOC1650 firmware and it was worked without any problems.
5/9/2022 5:03:59 PM •
Advance...
Answered
on May 09, 2022
What is a simple way of AOL Mail Login Solution?
SHUBHI GUPTA, Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
11/6/2019 10:49:22 PM •
Advance...
Answered
on Nov 06, 2019
Any one having schematic of Tenma 72-8350A psu
the maker does not provide that to the public,
but if you learn to google , you might find
LEAKED documents.
it is a bad PSU< here in USA we REPLACE it.
why ? because if the PSU goes nuts, it can blow up $1000 worth of electrionics, even a blown up $500 CPU or same GPU.
why risks your PC like that?, odd.
here is my fav, pirated schems, site.
join and look, ok?
https://elektrotanya.com/showresult
7/23/2019 3:55:29 PM •
Advance...
Answered
on Jul 23, 2019
