20 Most Recent
SanDisk Ultra Plus 64GB SDXC Class 10 UHS-1 Memory Card Questions & Answers
Recover deleted photos using mac
have you lost your photos on your memory card/USB drive?
If you appear to be a Mac user, just try this Photo Recovery app. It can nimbly recover deleted photo files, music sources and video clips from Mac hard disk drive and memory devices containing USB Drive and SD card.
http://www.leawo.org/photo-recovery-mac/
Simply insert the card to your Mac and run the photo recovery app. The software may help you scan the card and then show you files it has found. Choose the pics you want to get back and hit the "Recover" button to start.
Sandisk ultra write protected
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjijK-2oOeCAxX2k4kEHZN0CnEQrAIoAHoECCQQAQ&url=https%3A%2F%2Fforums.sandisk.com%2Ft%2Fremove-write-protection-from-usb-drive%2F33510&usg=AOvVaw3A01NeRgbLmAWvj17rGaBA&opi=89978449
11/28/2023 5:48:51 PM •
SanDisk...
Answered
on Nov 28, 2023
ACCIDENTLY DELETED MY LOCK
Just google "rescue my files"
Lots of sites are offering software to recover deleted files, or even files from a formatted drive.
Be aware, if you did write anything on the drive after formatting, it will decrease the chance of and the amount of files you can rescue.
Most sites offer a trail version wich you should use first, to see if there is still something to rescue. To my knowledge there were some good freeware programs, but not sure they are still there. I use a paid version, since I deleted a drive by accident
1/12/2020 2:42:20 PM •
SanDisk...
Answered
on Jan 12, 2020
How to connect sandisk wireless flash drive to a tablet without a usb port?
If it's Bluetooth / Wifi, you have to pair them first.
Are you 100% sure it's a flash?
If it has a usb port, then it could be a bluetooth or Wifi (wireless communications connection) dongle, not a storage flash drive.
A bluetooth dongle will usually have the double W symbol similar to a spiky 8.
If Bluetooth / Wifi:.....
USB has 4 pins - outer 2 are power to the device, while the inner 2 pins carry data traffic only.
Therefore a BT device, Wifi and a flash storage drive need to be connected to USB for powering its circuit board and relaying data.
Try this if BlueTooth:
Switch ON bluetooth on both devices (flash may have a button / switch, or not), most just use "Remove Device" "Safe to Remove" then yank it out to switch off (as no 5V USB BUS power = 0).
Plugging in powers it up. It's functions are controlled via PC's BT menu.
With BT Flash plugged in, go to your computers device settings or the taskbar may have a BT symbol (like two face-to-face W's).
After switching computer BT on, select "search for devices" or similar, depending on your OS.
It may find several BT devices in your area.
Other BT devices such as Mobile Phone can also find a computer dongle by using the external device's menu to "search" while computer is made "visible" (also vice versa).
10/5/2018 8:13:43 AM •
SanDisk...
Answered
on Oct 05, 2018
What is the life span of a SanDisk Cruzer?
It all depends on how it is treated. In your pocket they can last months or days or years. If its the only place with certain data you need a data recovery specialist to salvage it. In the future, you should use at least 2 devices(one cloud based) to guarantee proper storage.
6/4/2018 7:05:10 AM •
SanDisk...
Answered
on Jun 04, 2018
Mirco SD card shows free space 0 bytes and used space 0 bytes
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
6/9/2017 1:13:36 AM •
SanDisk...
Answered
on Jun 09, 2017
