20 Most Recent
Kyocera Hydro Icon - Prepaid Phone Boost Mobile Questions & Answers
Icon dropped in water for 5 seconds and now will not power on at all
well what you have to do is to remove battery. Dry phone and battery completely. get a plastic container with a lid fill with rice YES rice not cooked .submerge both phone and battery into rice fully covered pop lid on leave it for a few days hopely the rice will obsorb the remaining condensation. If it doesnt fire up after a charge its ruined sorry
Icon keyboard problem
Jason,
It sounds like you dropped your phone in water. I know that this model is supposed to be water proof, but a common symptom of water damage is random gibberish from the keyboard.
At any rate, the phone has to be taken in for servicing or replacement because there nothing that can be done without the tools a tech has. I'm sorry for the bad news.
Kyocera Phones Support Page
Take care and have a great day!
-Alex K.
How to bypass a pin code on lock screen on a Kyocera phone
All I can suggest for this is to take it to mobile phone specialist. They will have the tools to help. There is a possibility they will have to do a 'Hard' reset which often mean resetting to phone to factory settings. This means you risk losing your personal information like phone numbers, Photos and stuff you've saved on the phone. Pin codes are a security feature so naturally are hard to bypass.
Kyocera e4810 with which carriers
The Kyocera E4810 is also known as the Kyocera DuraForce Pro 2 and it is compatible with a variety of carriers in the United States, including:
- Verizon
- AT&T
- T-Mobile
- Sprint
- U.S. Cellular
However, it's important to note that some carrier-specific features may not work if you're using the phone with a carrier it was not originally designed for.
Regarding the issues you're experiencing with Tracfone, it's possible that the phone may not be compatible with their network or there may be a configuration issue. You may want to contact Tracfone customer support or visit a Tracfone retail store to see if they can assist you with getting the phone to work on their network
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
- From any Home screen, tap Apps.
- Tap Settings > More > Cellular networks.
- Tap Access Point Names.
- If available, tap the T-Mobile US APN.
- If not available, tap the New APN icon.
- To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
- Verify and update the following settings for the Data APN:
- Name: T-Mobile US
- APN: fast.t-mobile.com
- Proxy: <Not set>
- Port: <Not set>
- Username: <Not set>
- Password: <Not set>
- Server: <Not set>
- MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
- MMS proxy: <Not set>
- MMS port: <Not set>
- MMS protocol: WAP 2.0
- MCC: 310
- MNC: 260
- Authentication type: <Not set>
- APN type: default,supl,mms
- APN protocol: IPv6
- APN roaming protocol: IPv4
- Enable/disable APN: <greyed out unless there are multiple APN's>
- Bearer: Unspecified
- MVNO type: None
- MVNO value: <Not set>
- Tap the Menu icon with three dots, then tap Save.
- Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
- Tap Network operators.
- Wait while the device populates a list of available networks.
- Tap the desired network you wish to register on.
Switch 2G / 4G
- Tap Preferred network types.
- Choose from the following options:
- LTE/WCDMA/GSM (Auto mode)
- WCDMA/GSM
- GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
- From any screen, swipe down from the top of the screen.
- Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
- Tap to turn Data Roaming on or off.
Turn on / off mobile data
- From any Home screen, tap Apps > Settings > Data usage.
- Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547 If you need further help, I’m available over the phone at
https://www.6ya.com/expert/daniel_a4640839dbb7ec58
My instagram not working on my android
This happened with facebook on my android. First try resetting your phone (turn completely off then back on). If that does not work go to settings and completely uninstall Instagram. Go to play center and re download it.
How do you factory reset a kyocera hydro view C6742 from cricket?
HardReset.info: At the very beginning hold down the Power key in order to switch off the cell phone.
HardReset.info: In this step press and hold the Volume Down + Power button for a few seconds.
HardReset.info: You should release held keys when the Recovery Mode starts.
HardReset.info: Afterwards press Volume Down a few timies to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
HardReset.info:
Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select.
HardReset.info: When the Recovery Menu appears once more on the screen, choose "reboot system now".
KYOCERA CELL PHONE WILL NOT CHARGE PAST TWO BARS
If your cell phone is not charging I will suggest you to:
First, change the charger cable and check
If the above step does not work then, change the charger
Moreover, the last possible solution is changing battery.
