Question about Kyocera Cell Phones
How do you factory reset a kyocera hydro view C6742 from cricket?
I have tried hold volume up and power when phone comes on let go of power but hold volume,I've tried samething with volume down and power,tried volume down and power but let go of volume down when kyocera logo appears and push it back down after a couple seconds,I've tried volume down and power release power for a second when phones powering on and push it back down also with volume up and power with the same method and I can not get it to factory reset what am I doing wrong
Posted by Estelene Mitchell on
  • RachelCard
    RachelCard Nov 15, 2021
    . [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://www.netcash1.com
I need unlock code for Kyocera c6742 to unlock from Cricket network
How to Get the unlock code for Kyocera c6742 to unlock from Cricket network
Go to the link below
Unlock Kyocera C6742 How to Unlock Kyocera C6742
Choose:
-Country from The Phone Purchased:-
-Network on which The Phone Is Locked:-
-Mail ID
Place order by Updating the IMEI no. You will get the unlock code on your mail with in least possible time
How to factory reset kyocera hydro view when it doesnt work
An alternate reset method is available if the device can be powered on and is responsive.
  1. Ensure that the device is powered off. ...
  2. Press and hold the Volume Down button (figure 1) then press and hold the Power button (figure 2) until the 'Kyocera' logo appears (approximately 10 to 15 seconds) then release.
Forgot password for cricket kyocera model C6742
I am forgot password fort cricket kyocera model c6742
How do I factory reset?
You can find in settings Factory Reset/Backup.
Turn device off. Hold at same time power + volume button up. When screen boots up release power button but continue to hold down volume up.
How do I clear the msger/text notifications on a Kyocera HydroWave when all msgs/texts have already been opened w.o a phone reset? Deleted all texts, cleared/stopped msger/hangout apps already. Thanks
Try to reboot your phone
To perform a master reset with the hardware keys, follow these steps:
  1. Back up all necessary data.
  2. Turn off the device.
  3. Press and hold the Volume down and Power key.
  4. When the phone vibrates, release the Power key.
  5. When the Android recovery screen appears, release the Volume down key.
Perform Factory Data Reset Device Powered Off Hydro ELITE by Kyocera
Screen has lines through it
Try this, but this wll also wipe all data from your phone. so back up your stuff first
Step 1 Power down the Kyocera Hydro smartphone. If the phone is frozen, pull out the battery, wait a few seconds and reinstall it to ensure the phone is off.
Step 2
Press and hold the "Volume Down" button and then hold down the "Power" button.
Step 3
Release the buttons after a few seconds when you see the Android System Recovery screen.
Step 4
Press the "Volume Down" button to highlight "Wipe Data/Factory Reset" and then press the "Power" button to select it.
Step 5
Select "Yes -- Delete All User Data."
Step 6
Select "Reboot System Now" to complete the reset.
2answers
2helpful
How do I find the bootloader for my kyocera hydro phone. I am trying to get it out of the safe mode
you guys are idiots! it's a Kyocera not a Motorolla! The Kyocera Hydro's bootloader is Locked down, same with it's twin the Rise. So until someone figures out how to unlock the bootloader your stuck. have you tried reseting to facotry defaults?
If not here is your instructions and this might help you ^_^
First you remove the battery and reinstall it. With the phone turned off, Press and Hold the Volume Down and the HOME Touch Screen Button (The one theat looks like a little house), and without releasing those two press the power button long enough until you see the Kyocera Hydro logo, when this happens you may release the power button BUT NOT the Home and Volume keys. After a couple of seconds you will see a big android logo on your screen, NOW you can release both buttons. With the volume keys scroll down to WIPE/FACTORY RESET (This will erase everything on your phone except the contents on your MicroSD card). With your power button you select the option of WIPE nad after that it will prompt you with a lot of NO and one YES, scroll with the volume button then choose with the power button. After this you will return to the previous menu, so you just choose the REEBOT NOW with the power button, and voila MASTER RESET.
Cell Phones Logo
Top Kyocera Cell Phones Experts
john h
matt
matt
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
