20 Most Recent
Stanley Classic 99 Utility Knife - 10099 Questions & Answers
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
My sloan flushmate toilet makes
this has already been answered on another site click here
http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
- Remove the ceramic cover from the tank on the back of the toilet.
- Fill a one-gallon jug with water.
- Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
- Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM •
Home
Answered
on Mar 14, 2024
