Question about Home
How to clean mold from a shower - Home
Posted by steve kelly on
  • Anonymous Jul 22, 2020
    rinse off with clean water. we are from Pepetrip acertified packers and movers company.http://pepetrip.com/packers-and-movers-c...
Mukesh Panda
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
1. Make your bleach solution i.e. mixed up in the spray bottle (1 half bleach to 2 half water).
2. Do spray the same solution onto the mold affected grout. If you have enough time, then spray all the grout all over the shower.
3. Take your scrub and nylon brush the mold from the shower grout.
4. Rinse off with clean water.
If you shifted your home recently then this technique will work. You should check those before shifting. Actually I have shifted recently and suddenly found this type of issues in my home. I applied this solution and that worked. According to me here is a reliable home shifting service provider. You can hire it for the best quality of home shifting services. Here it is https://www.assureshift.in/packers-movers-pune-to-mumbai
Posted on Feb 26, 2020
Leroy Elliott
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 425 Answers
Full strength bleach...let soak 24 hrs
Posted on Feb 20, 2020
Can i clean a mouldy shower with the green compact steam cleaner?
Use a mold and mildew remover spray to clean the shower. The best one is made by "TILEX"
Sep 28, 2017 | Vacuums
What can my neighbor lady use to add a back to her shower caddy?
I would recommend cutting a vinyl shower curtain to fit. Otherwise, if you'd prefer a hard back, you can usually find some relatively thick plexiglass that should do the trick nicely. It wont rust, because it isnt metal, isnt likely to mold or mildew up too bad, and it's pretty easy to clean and resists alot of different cleaners pretty well. Hope this helps
May 09, 2016 | Home
Shower walls
You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
Jul 06, 2013 | Tools & Hardware - Others
How to clean mold from shower tiles
Cosmo ceramics do a cleaning kit for ceramic tiles
Nov 03, 2012 | Home
bleach. spray it on and leave it.. make sure you have good ventilation and never mix it with anything else. if the tiles have caulking around them then you will probably have to get a grout tool to remove it and then re-grout. good luck
Nov 03, 2012 | 2002 Dodge Grand Caravan
I have mold on a plaster wall - how do i fix mold on a wall with mold
Clean the wall with bleach and then paint the walls with anti-fungal paint.
If this room is a bathroom then install an exhaust fan to draw out the moisture when you take a shower.
Oct 28, 2012 | Dell Inspiron E6550 Notebook
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
I would like remove old vinyl shower wall and install a tile wall. but do i have to remove the drywall also? I'm keeping the shower base.
if the sheetrock is in good shape you should not have any problems. If you are worried about mold and mildew, you might want to change out the drywall with either green coat or yellow coat- these are mold and mildew resistant
Nov 04, 2009 | Home
Home Logo
102 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
