20 Most Recent
JVC RX-6040 Receiver Questions & Answers
I have a Jvc Rx-6040b
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Rx6040b receiver
I need to know how to hook up all the wires to the to dvd tv cd every thing where does the wires go help me help me please i want to watch tv where it sounds good so if some some one can help me i will be very gratefull thanks
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
