It does have an aux input with two levels but this isn't suitable for a turntable.
A suitable input should have RIAA correction with a sensitivity of just a few millivolts for a magnetic cartridge.
Instruction manual can be found on the link below...
http://resources.jvc.com/Resources/00/00/90/LVT1519-001C.pdf
SOURCE: mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
SOURCE: connecting input & output on my TOA 900 series amp
http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
SOURCE: IS THIER A AUX INPUT FOR A 1998 A4 RADIO
not sure check with manual or talk to a stereo shop i think there is a connection that fits on to the aerial cable. joe
SOURCE: insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
SOURCE: When playing records on my turntable, the right
Check the wires to the cartridge, they can come lose and need to be tight. If that doesn't solve the problem check or replace the connecting cables. You can confirm it's not the pre-amp of your amp by just swaping the cables. Then the left speaker should play up. If it is still the right, then there's a fault on the pre-amp. But it could be just bad soldering somewhere. Also take the bottom of the turntable and check the soldering of the cables inside it.
Use pins 6,7 and 8 i the ribbon cable from the cassette player as AUX.
