20 Most Recent In-Sink-Erator Insinkerator 45 Dura-Drive .50 Horsepower Garbage Disposal Questions & Answers
Possible bad capacitor in evolution premer
difficult to fix residential disposal when parts are not available http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/15/2014 5:04:58 AM • In-Sink-Erator... • Answered on Aug 15, 2014
Emerson insinkerator model 538
Remove with vacuum cleaner http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/15/2014 4:32:10 AM • In-Sink-Erator... • Answered on Aug 15, 2014
Can't get neck out
8/15/2014 4:29:15 AM • In-Sink-Erator... • Answered on Aug 15, 2014
Manual for 77-62
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Most residential disposals cannot be repaired Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/15/2014 4:28:45 AM • In-Sink-Erator... • Answered on Aug 15, 2014
Badger INSINKERATOR 5xp 3/4 HP HOW TO FREE JAMMED BLADES
Use a broom handle to turn the blades or use a wrench in the bottom of the unit. The wrench should have come with the disposal.
5/26/2014 4:15:54 AM • In-Sink-Erator... • Answered on May 26, 2014
I am an electrical equipment repairman. My
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html if you can take it apart and seal from water gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1/29/2014 7:34:16 AM • In-Sink-Erator... • Answered on Jan 29, 2014
Motor just hums,grinder wedges are free, no leaks apparent,motor turns free in both directions.
yes there is start capacitor on each motor, connected to start winding. There are two windings on each motor: start winding and run winding.Both windings receive power at same time. If the start winding is bad, or capacitor is bad, then motor hums as the run winding receives power but there is not enough torque to get the motor rotating.If motor is humming instead of rotating, then quickly the motor overheats and looses speed after repair or melts and fails.The problem with disposal repair is getting the thing apart... finding replacement capacitor, or replacement parts, and then reassembling without a leak.http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.htmlhttp://waterheatertimer.org/Color-codewire.html#motorhttp://waterheatertimer.org/Color-codewire.html#MotorGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/18/2013 4:40:42 AM • In-Sink-Erator... • Answered on Nov 18, 2013
Sinkmaster 850 Garbage disposer. I have to unplug my Sinkmaster 850 to stop it the switch isn't working.
Question edited for clarity. Question moved from Cars and Trucks. Parts suppliers and the maker. https://www.google.com/search?q=sinkmaster+850+replacement+parts ..
4/12/2024 5:52:32 PM • Garbage... • Answered on Apr 12, 2024
2answers
Garbage disposal electrical shock.
Are you sure it wasn't a static electric shock, rather than AC? If you live in a dry climate, or in a cold climate without a humidifier, and you may have walked across a carpet, it could have been a spark of static electricity. Especially if it hasn't reoccured.
4/12/2024 8:40:38 AM • Garbage... • Answered on Apr 12, 2024
3answers
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
11/2/2022 7:28:51 AM • Garbage... • Answered on Nov 02, 2022
Removing viking 1030 garbage disposal
5/21/2022 11:43:46 PM • Garbage... • Answered on May 21, 2022
How do I unclog a T-1060 Waste Disposer
TURN OFF POWER before sticking your hand in.!! But first check the reset button underneath the unit. Also, try to rotate the spinner with hex key usually provided. garbage disposal 2-r5bj5m104gwgi1atksjipnx0-5-0.jpg garbage disposal-r5bj5m104gwgi1atksjipnx0-5-2.jpg
1/17/2019 7:14:36 AM • Garbage... • Answered on Jan 17, 2019
2answers
What is perspective of waste management by
Drink beer and then recycle glass bottle or aluminum can Then research recycling route for all recycled and non-recycled waste products If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/4/2018 10:41:22 AM • Garbage... • Answered on Dec 04, 2018
Does insinkerator have a start capacitor?
Yes... all motors have start capacitor .. ''Without a start capacitor when voltage is applied, the motor would just hum''
10/11/2018 5:44:15 AM • Garbage... • Answered on Oct 11, 2018
How to install a kitchen food disposal?
Go to utube and watch the film.
12/26/2017 12:43:53 AM • Garbage... • Answered on Dec 26, 2017
Unclogging garbage disposal
Hello, Tom -You may find this instructional YouTube video helpful:https://www.youtube.com/watch?v=qC8LN32ep_Q
12/22/2017 5:00:17 PM • Garbage... • Answered on Dec 22, 2017
My garbage disposal is stopped up how do I fix it?
Following link has step-by-step and illustrations: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:05:26 AM • Garbage... • Answered on Nov 11, 2017
How to fix leaking 901 sinkmaster
Following link has troubleshoot resources and step by step: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:04:41 AM • Garbage... • Answered on Nov 11, 2017
In-Sink-Erator Insinkerator 45 Dura-Drive .50 Horsepower Garbage Disposal Logo
1 questions posted
Top In-Sink-Erator Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an In-Sink-Erator Garbage Disposal Expert? Answer questions, earn points and help others
View Most Popular
  • In-Sink-Erator Garbage Disposals
Most Popular Question
removed drain from unit as cloth stuck
  • Garbage Disposals
