20 Most Recent
Bose 141 Main / Stereo Speaker Questions & Answers
Bose 141 will not work
hello in this case this boxes are sealed to ensure a rich sound do this check where they bond together try to apart, im sure you already check with a baterry and ohmeter in the connector of the speaker see how many ohms you have about 4/8 omhs or even a broken wire inside the cabinet cause very old .....saludos
Pyle P22-03ABTU stereo receiver.
Question edited for clarity. It is a 'Pyle' not a 'Pile'.
It is under warranty. Return it, an internal component has failed probably an electrolytic capacitor.
One thing you can try is to disconnect it and move it to another room to discount EMF from something.
Bose wave radio doesn't turn on with the remote but one time in 20 to30 times pushing the power button.
You can check with new battery in the remote. Next you point a digital camera, a smartphone should do fine, at the infra red transmitter on the front of the remote and then look on the camera screen if you see the ir light flash different pulses for each button. Infra red light can not be seen but a digital camera shows it really well. Confirm this with another remote. Now you know if the remote functions right. Remotes are available on-line or one can use a universal type remote. The IR receiver is often welded onto the circuit board. This means that it is not right behind the front panel window. It can be obstructed, perhaps by dust or displaced. This is generally speaking.
