20 Most Recent
Gateway Realtek RTL8185 54M Wireless LAN Network Adapter Questions & Answers
My driver detects wireless networks then for no reason doesnt detect any then i restart my computer then it detects them again. wat could be the problem?
Make sure you get the Realtek Wireless Lan Utility; if you're not using it now you're lucky you can connect at all.When you get that installed, or if you already have it, find the file in the REALTEK install folder called 8185.ini (or 8185x64.ini on a 64 bit OS), delete everything in it, and paste this into it. It'll give you more control over the card and open up new options in the wireless utility.[Country]AutoSelected=1xxnCountry=2[WLan Utility]WZC=0RtWLanTitle="REALTEK RTL8185 Wireless LAN Utility"MANUFACTURER="REALTEK"Model_Name="REALTEK RTL8185 Wireless LAN"NO_Adapter_TEXT1="REALTEK RTL8185 Wireless LAN Utility"NO_Adapter_TEXT2="Realtek Semiconductor Corp."NO_Adapter_TEXT3="Copyright (c) 2003-2009"[UI Config]ICS_Page_SHOW="1"MACfilterPage_SHOW="0"AP_Mode_ENABLE="1"AP_Mode_WPA_PSK_ENABLE="0"WPA2_ENABLE="0"AP_WPA2_ENABLE="0"WDS_AP_Mode_ENABLE="0"RT_SET_ENABLE="0"802_1X_SHOW="1"Link_ANY_ENABLE="0"EzConfigPage_SHOW="1"SimpleConfigPage_SHOW="1"WiFiProtectSetPage_SHOW="1"External_Registrar_SHOW="1"AdvancedPage_SHOW="1"DbgWnd_SHOW="1"WLANModeTo90="1"PowerSave_SHOW="0"TurboMode_SHOW="1"WirelessMode_SHOW="1"PREAMBLE_SHOW="1"Channel_Plan_SHOW="1"XLink_SHOW="1"WMM_SHOW="0"RTS_Threshold_SHOW="1"Fragment_Threshold_SHOW="1"WOL_SHOW="0"DATA_RATE_SHOW="0"Throughput_SHOW="0"VWiFi_SHOW="1"[98UI Config]AP_Mode_ENABLE="1"AP_Mode_WPA_PSK_ENABLE="0"WPA2_ENABLE="1"WDS_AP_Mode_ENABLE="0"RT_SET_ENABLE="1"802_1X_SHOW="1"EzConfigPage_SHOW="1"SimpleConfigPage_SHOW="1"WiFiProtectSetPage_SHOW="1"PowerSave_SHOW="1"TurboMode_SHOW="1"WirelessMode_SHOW="1"PREAMBLE_SHOW="1"Channel_Plan_SHOW="1"XLink_SHOW="1"WMM_SHOW="1"RTS_Threshold_SHOW="1"Fragment_Threshold_SHOW="1"WOL_SHOW="0"DATA_RATE_SHOW="0"
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
- Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
- Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
- Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
- Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
- Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM •
Gateway...
Answered
on Feb 26, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM •
Gateway...
Answered
on Feb 21, 2023
My Gateway ZX6980 Card Reader will not work?
Please test multiple cards in the reader to ensure that 1 individual card isn't the problem. Then, you can restart your computer after running a virus scan. Thank you.
7/29/2022 12:41:43 AM •
Gateway...
Answered
on Jul 29, 2022
