20 Most Recent
Clarion ADX8255 Questions & Answers
Error message 'accs' appear, what
busque el boton de reset y oprimalo si no tiene entonces desconecte la bateria del carro por unos 30 minutos para que reinicie con configuraciones de fabrica ojo verifique que no sea antirrobo esa version si es asi posiblemente tenga que introducir la clave que biene con los documentos del due?o original
Wire coler for 12v
hi the + is normally red or yellow ..yellow being the constant power to keep memory and the red to ignition which only gets power when the engine is running, the - is usually black, but some models have a brown - wire hope this helps please vote thanks
Kent
did you try resetting it? I'm not sure if that works but its a shot. The reset button is a pin-hole next to the 123456 buttons
Code for clarian stereo
I have a 206 cc with a built in clarion cd and radio, the cd player does not work. my girlfriend has a 307 with the same cd player.I want to swop them both over but when i do they both bleep! this must be the anti-theft device kicking in. How do i swop them? darren fom haworth
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
