Hi the + is normally red or yellow ..yellow being the constant power to keep memory and the red to ignition which only gets power when the engine is running, the - is usually black, but some models have a brown - wire hope this helps please vote thanks
Left Front Speaker Positive Wire (+): Gray/Violet Left Front Speaker Negative Wire (-): Gray/Yellow Right Front Speaker Positive Wire (+): Dark Green/Violet Right Front Speaker Negative Wire (-): Dark Green/Yellow
Left Rear Speaker Positive Wire (+): Gray/Dark Green Left Rear Speaker Negative Wire (-): Gray/Light Green Right Rear Speaker Positive Wire (+): Dark Green/Gray Right Rear Speaker Negative Wire (-): Dark Green/Light Green
the case you have disconnect on the ground ( brawon coler) inthe claster . all guage have one ground check the braown coler wire but don't remove or disconnect the calster it may lose key prog try disconnect battarry then check from guage bording up to dash bord bracket . try make sure you have no short with any sender ( fuel .tem. or speedo)
For Pioneer car stereos to keep the station memory the wiring is as follows:
Yellow is 12v constant
Red is on with ignition switch.
Orange/white is for lighting switch.
as for display color, need to know the head unit model.
find the trunk relese wires in the loom going to rear find the correct colers from your wireing diagram cut them, pear the wires going to trunk...simpely trip the lock with a 12 volt alarm battery or somthing like that any thing that can give it 12v O.K.?
make sure screen is 9300 coler mode o sum sort of natural mode so u see real colers unless screen bad need nice cleaer screen natual coler user usally setting is best then look colers adjust photo downkload latest drivers for printer too from website vs cd
direct to front s out from sterio have to match up know were your old ones go a wire harness for your car says all labeled nice were to go weird colers in such ok get that match it up to back of head unit wireing it direct ok postive on + negitive on - ok its notto hard if u dont know colers u call deler they tell u the coler codes for your car write it down ok
