20 Most Recent
Mitsubishi HS-U560 VHS VCR Questions & Answers
Part for VCR mechanism
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Unable to load a cartridge. The 'carrier' remains
It is possible that that it may have a processor that is locked up. or the electronic sensors are not , sensing the tape, unplug from wall for 30 MIN> and that will reset the processor if that is the problem.
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
VCR started eating tapes.
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
Yes - There are cassettes available that are made out of clear plastic that allow you see what's happening. You can also trick the player into thinking there is a tape. There are sensors (mechanical & infrared sensors) that you can bypass.
- Jim
A tape is stuck in my VCR. and i cant get it out, How can I remove it?
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
