20 Most Recent
Mitsubishi VS-70601 70" Rear Projection Television Questions & Answers
70 ' MITSUBISHI tv model vs-70601 shut off
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; [Exclude the model number], in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts. //
Vs-70601 mitsubishi tv was working fine one day,
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I'm having a problem with my mitsubishi vs-70601.
Hi.
The clicking noise and the TV remaining in standby indicate the the unit is on protect mode.
This happens when an internal fault is detected.
Since there is no indication that the PSU is faulty, more parts must be tested. The Flyback transformer is commonly failing.If there is trace of burning, test and eventually replace the flyback.
Part number is # 334P246060 , here the part:
334P246060.
Regards.
Disconnect all the cables from the TV then connect the power cord from the TV to different functional wall outlet to check if the TV is powering ON.
If the TV is not showing any sign of power then press and hold the power button on the TV for 30 seconds to discharge all the capacitors that may be causing the issue.
If the TV is not powering ON even after performing all the above steps then the capacitors on the power board are burnt out and requires to be replaced.
11/15/2009 11:59:01 PM •
Mitsubishi...
Answered
on Nov 15, 2009
Have a Mitsubishi vs 70601 shut off by itself one day and wont po
i would think it is going to be the main fuse, open the back of the tv, you will see where the power cord is connected to the board, there will be a glass fuse next to it, you will be able to see if it is bad,----make sure you unplug the tv befor you mess with it
My tv picture is all screwed up
Your convergence ICs are bad STK392-110 you can get new ones for about 10.00 each. They are located on the left side of your chassis a large heat sink. They will need to be soldered in. Also check the resistors right next t the heat sink. Sometimes 1 or 2 of them go out along with the ICs.
