20 Most Recent LG DLEX2801 Electric Dryer Questions & Answers
Electric LG DLEX2801W (steam dryer) not heating.
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
5/16/2014 9:13:02 AM • LG DLEX2801... • Answered on May 16, 2014
Electric LG DLEX2801W motor stopped mid cycle. Still spins but slowly and loudly
First, remove the top and see if the belt is really lose.
11/18/2012 4:15:15 PM • LG DLEX2801... • Answered on Nov 18, 2012
It does not stop trumpling
timer contacts sounds like timer may need to be looked at its not breaking connection when it should be.
7/4/2011 7:16:57 AM • LG DLEX2801... • Answered on Jul 04, 2011
We have a DLEX 2801 front loading LG dryer. It
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. The vent holes you described that look burnt is the heat intake for the dryer. Almost all dryers look like this and it is normal.
2/2/2011 11:28:34 AM • LG DLEX2801... • Answered on Feb 02, 2011
Lint seems to get past the filter and has caused
You will need to disassemble the dryer and clean it out properly.
Good luck
10/4/2010 12:53:48 PM • LG DLEX2801... • Answered on Oct 04, 2010
LG Gas Dryer will not come on and throwing error codes.
It is a gas appliance and can only be worked on by a registered gas appliance technician. They will have access to the codes, they are generally hidden to the general public. Call for service.
8/24/2023 6:10:10 PM • LG Dryers • Answered on Aug 24, 2023
2answers
Trying to help my mom fix her dryer. Its a LG sensor dryer (DLEX3001R) ... ITS Plugged in but when you push the power button to turn it on it does nothing.. Any suggestions
Disconnect from power source by turning off breaker or disconnect plug.
Press START/STOP button several times. Reconnect power.
Check power at dryer electrical outlet with DMM if possible.
8/5/2023 3:48:33 PM • LG Dryers • Answered on Aug 05, 2023
How do you change the roller posts for LG dryer DLG8388WM so it fits LG's recommended roller, AGM75510755?
I have spent half an hour researching the question as I noticed it wasn't answered since I read it last night.. K250 and K251 on the schematic. Is your post the wrong diameter? It looks a standard swap over and none of the parts suppliers mention any modification. That makes mw wonder if yours are mislabeled. https://www.searspartsdirect.com/model/192s9c7uvq-003204/lg-dlg8388wm-dryer-parts https://www.partselect.com/PS16763594-LG-AGM75510755-PARTS-ASSEMBLY-SVC.htm?SourceCode=19&SearchTerm=DLG8388WM&ModelNum=DLG8388WM https://www.google.com/search?q=lg+dryer+dlg8388wm+drum+roller+replacement ..
7/12/2023 6:17:29 PM • LG Dryers • Answered on Jul 12, 2023
3answers
LG Dryer won't start beeps twice, it's brand new.
Two beeps is typical door not closed. Make sure the light goes out when you close the door. Otherwise make sure both Clean Filter and Flow Sense lamps are off. You can run the installation test. See following URL. https://www.lg.com/us/support/help-library/how-to-run-and-installationheat-test-on-an-lg-dryer-CT10000011-20152714315153
6/23/2023 2:41:11 PM • LG Dryers • Answered on Jun 23, 2023
2answers
The dryer light is blinking on my new lg dryer
refer to owners manual. Since you did not indicate what light is blinking here is a link to LG error codes copy and paste https://www.lg.com/us/support/help-library/lg-error-codes-laundry-dryer-CT10000011-20152310891742
5/6/2023 8:29:32 PM • LG Dryers • Answered on May 06, 2023
LG Smart Sense Dryer. The 'Check Filter' light is on. It won't start and makes a clicking noise. Help please.
Question edited for clarity and change 'want' to 'won't', a contraction of 'will not'. The check filter indicator is a reminder to clean the lint filter before each use to ensure effective drying every time. The indicator turns off when you turn the cycle knob to select a drying program or when the start/pause button is pressed. Apr 7, 2023
LG Dryer - Error Code List ' LG USA Support
LG https://www.lg.com > ... > SUPPORT > Register a Product
4/25/2023 3:19:01 PM • LG Dryers • Answered on Apr 25, 2023
LG dryer only drying on high heat.
The thermal fuse is faulty. Or the vent is clogged and no gas flow. Or there could be a faulty circuit breaker.
3/29/2023 9:28:47 AM • LG Dryers • Answered on Mar 29, 2023
2answers
LG Dryer dlex3360v sometimes starts and shuts off after a fews seconds. It works most of the time.
possible flame sensor dirty or bad or burner tube has blockage
3/25/2023 6:00:16 AM • LG Dryers • Answered on Mar 25, 2023
LG DLE7100W DRYER detached something?
It's difficult to determine exactly what may have fallen behind the panel of your LG DLE7100W dryer without a visual inspection. However, it's possible that you may have accidentally detached a small part or screw that was holding something in place. The rolling sound that you're hearing when the dryer is turned on could be a loose part or screw that has fallen behind the panel and is now moving around inside the dryer. This could potentially cause damage to other components if left unaddressed. I would recommend stopping any further attempts to disassemble the dryer and instead, contact a professional technician to inspect and repair the dryer. They can determine what may have fallen behind the panel and take the necessary steps to fix it safely and properly.
3/18/2023 5:43:26 PM • LG Dryers • Answered on Mar 18, 2023
What does this symbol mean on my LG TD-C70080E condenser dryer?
Unfortunately, without a picture of the symbol you are describing, it is difficult to give a precise answer. However, based on your description of the symbol and the accompanying burning plastic smell, it is possible that the symbol is indicating an issue with the dryer's motor or belt. The symbol you are describing with the oval and arrows could indicate a rotating part, such as a drum or belt, and the smell of burning plastic suggests that something in the motor or belt may have overheated and melted. It is important to immediately stop using the dryer and unplug it from the electrical outlet until you can determine the cause of the issue and make any necessary repairs. It may be best to contact a professional technician or LG customer service for further assistance and to avoid causing any further damage to the dryer.
2/28/2023 5:24:02 AM • LG Dryers • Answered on Feb 28, 2023
What caused LG Combo Washer door gasket to melt?
Not enough airflow, and the dryer producing too much heat. Check the vent at the rear, the hose and the flap on the outside wall for lint and obstructions.
1/20/2023 5:44:42 AM • LG Dryers • Answered on Jan 20, 2023
LG DLEX2801 Electric Dryer Logo
6 questions posted
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
electric lg dlex2801w motor stopped mid
  • Dryers
