20 Most Recent
GE 52048 24Hour Heavy Duty Appliance Timer Questions & Answers
GE washer 175D2750G335 won't turn on
If your GE washer's timer display turns on but the cycle doesn't start when you press the start button, there could be a few potential reasons for this issue. Here's a troubleshooting guide to help you diagnose and potentially fix the problem:
- Check Power Supply: Make sure the washer is properly plugged into a working electrical outlet. If the outlet is functioning correctly, you should see the display light up.
- Door/Lid Lock: Most modern washing machines have a safety mechanism that prevents the cycle from starting if the door or lid is not properly closed and locked. Ensure that the door or lid is closed securely and that the lock mechanism is engaging properly.
- Pause/Cancel Button: Some washers have a "Pause" or "Cancel" button that might need to be pressed before starting a new cycle. Check if your washer has this feature and if it's engaged.
- Child Lock: Certain models have a child lock feature that can prevent the washer from starting. Check your washer's manual to see if this is the case and learn how to disable it.
- Error Codes: Look for any error codes or messages displayed on the screen. These codes can provide valuable information about what might be causing the issue.
- Reset the Washer: Try resetting the washer by unplugging it from the power source for a few minutes, then plugging it back in. This can sometimes clear minor electronic glitches.
- Water Supply: Ensure that the water supply to the washer is turned on and the water hoses are not kinked or blocked.
- Drainage: If the washer believes there is still water in the tub from a previous cycle, it might not start a new one. Check if the drain hose is properly connected and not clogged.
- Timer/Control Board: If none of the above solutions work, there might be an issue with the timer or control board. These are complex components that might require professional diagnosis and repair.
- Professional Help: If you're unable to diagnose or fix the issue on your own, it's recommended to contact a professional appliance repair technician. They can accurately diagnose the problem and suggest the appropriate solution.
Remember, safety is important when dealing with appliances. If you're uncomfortable with troubleshooting or repairing the washer yourself, it's best to seek professional assistance.
Need color codes to timer switch for model DSKP333EC5WW
The color codes for the timer switch for model DSKP333EC5WW are as follows: Red - Power, White - Start, Black - Common, and Blue - Ground. The red wire needs to be connected to the power terminal, the white wire needs to be connected to the start terminal, the black wire needs to be connected to the common terminal, and the blue wire needs to be connected to the ground terminal on the new timer switch GE part # WE04X23897.
Where can I purchase timer wheel for GE 15164
You can purchase a timer wheel for a GE 15164 timer at a number of different places, including:
- Home improvement stores: Many home improvement stores, such as Home Depot and Lowe's, carry a wide range of timer parts and accessories, including timer wheels. You may be able to find a timer wheel for your GE 15164 timer at one of these stores.
- Online retailers: You can also purchase a timer wheel for your GE 15164 timer online through a retailer such as Amazon or eBay.
- GE Parts Store: You can also purchase a timer wheel directly from the GE Parts Store, which is the official parts and accessories store for GE appliances. To find a timer wheel for your GE 15164 timer, you will need to search for the specific part number for the timer wheel, which should be listed in your owner's manual or on the manufacturer's website.
- Appliance repair stores: Finally, you may be able to purchase a timer wheel for your GE 15164 timer at an appliance repair store. These stores often carry a wide range of appliance parts and accessories, including timer wheels.
It's always a good idea to check with multiple sources to find the best price and availability for the timer wheel you need.
I have a Ge sun smart in wall digital timer and it calls for a neutral wire. What is a neutral wire
Neutral is a circuit conductor that normally carries current back to the source. Neutral is usually connected to ground (earth) at the main electrical panel, street drop, or meter, and also at the final step-down transformer of the supply. That is for simple single panel installations, for multiple panels the situation is more complex.
In the electrical trade, the conductor of a 2-wire circuit connected to the supply neutral point and earth ground is referred to as the "neutral"
