Not sure if it is normal (probably not) but it is certainly reason to check it is being used only with a filament lamp (not fluorescent, not CFL, not led) and the ground connection to the switch is good.
If all is ok and the glowing light bothers you it will be time to buy a new switch but if it doesn't bother you and if the switch isn't heating up, there seems no urgency to replace it.
Testimonial: "I think the answer is that the bulb is an LED. I checked. Thanks. Figured as much, but wanted to be sure before running around changing this that and the other thing. TY again."
