20 Most Recent Proteam ProForce® 1500XP Bagged Vacuum Questions & Answers
Does the proteam proforce 1500xp automatically adjust itself for high or low carpet scenarios?
This vacuum cleaner has no height adjustment. You can run it across any type of carpet without making adjustment. You should turn off brush roller when using on hard floors.
12/2/2021 11:34:51 AM • Proteam... • Answered on Dec 02, 2021
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
10/4/2014 10:39:54 PM • Proteam... • Answered on Oct 04, 2014
0answers
Beater bar does not turn and belt is good
Are you sure you have the switch in position 2? The brush will not turn if the switch is in position 1 or if the handle is upright.
4/13/2014 2:10:32 AM • Proteam... • Answered on Apr 13, 2014
0answers
Brushes don't turn
Be the first to answer 2/25/2014 3:37:40 AM • Proteam... • Posted on Feb 25, 2014Be the first to answer
0answers
0answers
Proteam proforce 1500xp machine won't start?
Check the fuse or the or the wire, could be broken
3/28/2013 3:51:49 PM • Proteam... • Answered on Mar 28, 2013
Vacuum runs for awhile and then shuts off
This sounds like an overheat issue. I suspect that something has restricted the air flow. Air flow is required for function and to cool the motor. if the air flow is restricted a thermal limiter opens the circuit, rather than have a fire.
3/4/2013 2:56:49 PM • Proteam... • Answered on Mar 04, 2013
2answers
I will like to know
The part number is 105147. It can be ordered here: http://www.monsterjanitorial.com/proteam/p198/Proteam_105147_-_Switch,_Handle/product_info.html?osCsid=en87jr2q4166a52t513qvc1fb7
I've include a link to the parts diagram for future reference.
http://www.monsterjanitorial.com/partsdiagrams/proteam/proteam_proforce_1500xp_parts.pdf
You can also buy the switch from your local Aerus Electrolux store. It's the same machine as the Ultralux upright. For the store nearest you, follow the below link.
http://www.aerushome.com/storelocator/
10/23/2012 3:14:09 PM • Proteam... • Answered on Oct 23, 2012
0answers
Not powering on when plugged
Change the bag. It has an automatic bag full shut off switch.
4/15/2011 5:07:15 PM • Proteam... • Answered on Apr 15, 2011
Proteam Pro force 1500xp Upright vacuum... When I
Just undo the screws on the front part of the switch assembly, carefully check all the leads to the switch. Mine slide off all the time as the switch is poorly designed and subject to damage when the darn thing tips over (easily!!!) new switches are about 7.50 USD.
2/11/2011 9:06:28 PM • Proteam... • Answered on Feb 11, 2011
0answers
0answers
Proteam ProForce® 1500XP Bagged Vacuum Logo
20 questions posted
Top Proteam Vacuums Experts
john h
Are you a Proteam Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Proteam Vacuums
  • Proteam Vacuums
Most Popular Question
beater bar not turn belt good
  • Vacuums
