20 Most Recent
Proteam Everest Vacuum Questions & Answers
Backpack vacuum trips breaker how do I locate the ground short
If this machine has functioned well in the past and this problem has showed up suddenly, with no damage having been done to the machine, then start with the cord. Check for dings, scrapes, anything that could get down into the actual wires inside. If you don't find anything there, then you'll need to take the unit apart where the cord enters and trace it to the motor. You'll need an ohm meter to check continuity. When you find a point where two wires are touching each other or the outside body of the unit that will probably be your problem area.
Very weak suction
Is this a back pack or upright? Need more information. Model # for upright.
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
