20 Most Recent Zyxel USG 200 (ZWUSG200) Firewall Questions & Answers
How can I recover my password on USG 200?
Like most of security products, you can not recover the password but you can reset the device and login the device with default password.
4/20/2014 3:44:29 AM • Zyxel USG 200... • Answered on Apr 20, 2014
0answers
Can I use a Zyxel VMG3625-T20A router as a range extender?
Question edited for correct name of maker, add a few capitals. Question moved to Zyxel Router. There is some advice here. https://forums.techguy.org/threads/solved-how-do-i-bridge-my-router.1144390/ https://www.google.com/search?q=use+a+Zyxel+VMG3625-T20A+router+as+a+range+extender ..
3/31/2022 9:08:13 PM • Zyxel Computers... • Answered on Mar 31, 2022
I cannot log into my ZYXEL VMG3625-T20A router admin panel after changing access password
google router and forgot password or locked out
1/7/2020 4:26:12 PM • Zyxel Computers... • Answered on Jan 07, 2020
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next? Login to Your ZyXEL Router Using the Router Password Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: =============== Forgot Router Password? If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings. What should you do? Login to Your Router Using the Default Router Password Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides. Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!) Find Your Default Router Password Simply select your router manufacturer from the list below to display the default router passwords and usernames.
8/3/2019 7:47:05 AM • Zyxel Computers... • Answered on Aug 03, 2019
2answers
Advent 9315 wifi
How are you connecting to the internet? 1. Wireless 2. Wired This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it. A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.) How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
1/8/2019 9:08:16 AM • Zyxel Computers... • Answered on Jan 08, 2019
Zyxel tm6841g firmware
username aur password kya hai
7/8/2018 1:03:23 PM • Zyxel Computers... • Answered on Jul 08, 2018
I have dlink cloud cameras and a dlink n150n cloud router am i going to have problems setting up the cameras .
Should be an easy task, you would just need to go through the manual, it's explained quite well. If you don't have the manual with you, then just download one from the internet: D-Link DCS 932L PDF Manual Download
6/24/2018 1:15:55 PM • Zyxel Computers... • Answered on Jun 24, 2018
2answers
I am computer illiterate. Someone gave me this ZyXEL P600 series. How do I use this, and what does it do?
Hello, Roger - The ZyXEL P600 appears to be a wireless computer modem / router (WiFi modem / router.) To use it with a computer, you will need Internet service (a paid internet service provider.) See the instructions here (Establishing a Wireless Network): http://support.brighthouse.com/Article/Connect-Computer-Router-6628/ In case the person who gave you the wireless router did not give you the instruction manual for it, the manual you can find here, may prove helpful: https://www.manualslib.com/manual/1054123/Zyxel-Communications-P-600-Series.html Personal opinion: Seek out reliable relative or friend who is knowledgeable about computers and wireless routers to assist and instruct you. You will need one-on-one help. Best wishes.
3/7/2018 10:30:56 PM • Zyxel Computers... • Answered on Mar 07, 2018
My parents have a Zyxel router for their WiFi. The password was changed a while ago but they don't have a record of it. How can we find it?
If the modem your talking about is the ZyXEL Prestige 623R-T1 ( that i believe is supplied with iol ), follow the reset sequence below ! 10. How to use the Reset button? Step 1: -------- Make sure the PWR led is on(not blinking)when you begin this procedure. Press the RESET button for ten seconds (or until the SYS LED starts blinking), then release it. If the SYS LED blinks, the defaults have been restored and Prestige restart. Otherwise, go to step 2. Step 2: ------- Turn the P623R-A1 off. While pressing the RESET button, turn the Prestige on. Continue to hold the RESET button. The PWR LED will begin to blink and flicker very quickly after about 10 seconds. This indicates that the defaults have been restored and the P623R-A1 is now restarting.
12/23/2017 6:38:48 PM • Zyxel Computers... • Answered on Dec 23, 2017
Red light - Internet
Not internet connection. You will need you IP to come check the lines.
11/14/2017 2:09:29 PM • Zyxel Computers... • Answered on Nov 14, 2017
0answers
Zyxel USG 200 (ZWUSG200) Firewall Logo
4 questions posted
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zyxel Computers & Internet
Most Popular Question
recover password usg 200
  • Computers & Internet
