Hi there's are 4 light which is on in yellow [LAN,WIRELESS,INTERNET,and another i forgot] I'm currently using modem provide by streamyx (Zyxel P600 series) and the light on INTERNET turns from yellow to red, like solid red, no blinking. Cant solve it by reseting the modem myself, not even by hitting the reset on the modem
SOURCE: ZyXel Prestige 660HW T1, power light blinking
It's dead, sorry. You could TRY removing the power cord, holding in the reset button and powering it back up with the button HELD DOWN for at least 10 seconds. That will factory default it, so I hope you know how to program it all again! (please don't contact me and complain if you don't...)
SOURCE: Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
SOURCE: I have no internet connection and a red light
It mean no internet connectivity, so don't worry.
SOURCE: zyxel modem and wrt54g modem
1 first thing you do, go to web based utility 192.168.1.1 login to the zyxel modem....then go to tool => configuration => reset.....
2. configure your router, go to web based utility 192.168.1.1 login ti the router....then go to basic set-up choose DHCP automatic confg... enabled dhcp 192.168.1.100
max dhcp user its up to you....
3. advanced routing choose gateway.....select set number 19 .... then interface lan and wireless....
4. connect all the cable attached.... then checked the status is connected.....
5. set your LAN into DHCP....
1. Determine if you can connect to the Internet using your computer. If you cannot connect, proceed to step 2.
2. Reset the router. Unplug the router for 30 seconds and plug back in. It can take a few minutes to reconnect to the internet. If you still cannot connect to the internet, contact your Internet Service Provider before proceeding.
3. Move the Internet Gateway ethernet cable to another port on the router. Put it in one of the ports on either side of the current position on router. Make sure that the Internet Gateway is plugged into a LAN port, normally numbered 1-4. Proceed to step 4 if none of the ports work.
4. If you are using a modem and a router, disconnect from the router and plug the Internet Gateway directly into a LAN port in the modem to bypass the router. Note: This will turn off the internet to the rest of your home network temporarily. If this works:
5. If step 4 doesn't work, power cycle your home's internet modem, it may need to be restarted to provide a new IP address to your network.
- Check your router How to determine which routers and modems are incompatible with the Liftmaster or Chamberlain Internet Gateway.
- Contact the manufacturer of your router for additional support. There may be a security setting preventing the Internet Gateway to connect.
6. Perform a Soft Reset on the Internet Gateway. This renews the IP address with the router. The LED lights will blink like a normal power up. To perform a soft reset:
1. With a safety pin or paper clip, press and hold reset button while the Internet Gateway is still plugged in.
Note: The reset button is located on the side of the Internet Gateway in a recessed hole.
2. Hold the button in until you see a yellow LED light blink and release.7. Perform a hard reset on the gateway. This deletes all the devices and renews the IP address with the router.
1. Unplug the AC adapter from the gateway.
2. With a safety pin or paper clip, press and hold the reset button on the side of the gateway.
3. Plug the AC adapter back in while continuing to hold down the reset button until the yellow LED light blinks.
