20 Most Recent Leica D-Lux 4 Digital Camera Questions & Answers
The lcd screen on my Dlux-4 Leica will not light up at all? any thoughts?
Did you try to press the display button (bottom rich, under the display) several times? The pressing will cycle through different settings, like display off.
6/16/2014 7:27:09 PM • Leica D-Lux 4... • Answered on Jun 16, 2014
Conect USB to a PC
Leica does not offer a driver for this camera on their web site. You might want to consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
4/30/2012 4:34:02 PM • Leica D-Lux 4... • Answered on Apr 30, 2012
Usb cord not working
New one from partmaster.co.uk
12/21/2011 9:33:47 PM • Leica D-Lux 4... • Answered on Dec 21, 2011
Black and white
You use b/w film mode.
12/13/2009 5:03:07 PM • Leica D-Lux 4... • Answered on Dec 13, 2009
Where can i get Original Leica TC 805 battery
Original as in made and supplied by Leica?
parts ' Leica Total Station
leicatotalstation.org https://leicatotalstation.org > tag > parts Parts for Leica total station for spares or repair. This item is in the category "Business, Office & Industrial\Test, Measurement & Inspection\Levels ... But lots of batteries here https://www.google.com/search?q=Leica+TC+805+battery
Leica TCR805 Battery - Replacement for Leica GEB121 ...
Amazon.com https://www.amazon.com > Leica-TCR805-Battery-Re... Leica TCR805 Battery - Replacement for Leica GEB121 Survey Instrument Battery (4200mAh, 6V, NIMH) -And also Leica DNA03, TCR-805 POWER, TCR-803 POWER, TCR405, ... Battery Cell Composition: NiMH Battery Capacity: 4200 Milliampere Hour (mAh) "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 56px;"> Rating: 3.9 · ‎4 reviews · ‎US$27.99 · ‎In stock
Leica TC805 2100mAh Replacement Battery
Batteries Global https://batteriesglobal.com > en-ca > products > leica-t... This Brand New Leica TC805 Battery (2100mAh Ni-MH 6V) Fits in and Replaces Leica 667147, 667318, TC1102, TC1102C. US$43.80
Leica TC805 Battery Replacement
BatteryShip.com https://www.batteryship.com > batteryship > catalog Leica TC805 Battery Replacement (battery condition: NEW) 6.0 volts 2100 mAh, NIMH. ... $81.30, Leica TC805 Battery Replacement 2.10Ah NIMH + Charger Rating: 5 · ‎1 review · ‎US$40.45
Leica TC805 Replacement Battery
Cut-Rate Batteries https://www.cutratebatteries.com > products > leica-tc8... Results 1 - 24 of 248252 - This Leica TC805 survey equipment replacement battery is compatible with the original equipment. Designed for reliable performance and ... US$38.79 ..
5/21/2023 7:35:57 PM • Leica Cameras • Answered on May 21, 2023
2answers
Leica Mini 3: When you open the back of your camera, does the counting of your pictures start again? Or is it a problem with my camera?
No, the counting of pictures on the Leica Mini 3 does not start over when you open the back of the camera. The camera uses an electronic frame counter to keep track of the number of exposures taken on the current roll of film. The counter should only reset to "S" (or "1" on some models) when you load a new roll of film. If you are experiencing a problem with your camera where the frame counter is resetting to zero when you open the back, it could be an issue with the camera's electronics or mechanics. In this case, it would be best to have the camera inspected by a qualified technician to diagnose and fix the problem.
2/28/2023 9:03:56 AM • Leica Cameras • Answered on Feb 28, 2023
How to get the Leica D-Lux 3 OUT of the Continuous Mode? the answer is NOT in the Instruction Manual. Thanks
To get your Leica D-Lux 3 camera out of the Continuous Mode, you will need to follow the steps below:
  1. Turn on the camera: Press the power button to turn on the camera.
  2. Change the mode: Press the mode button on the top of the camera until the Continuous Mode icon (a running person) disappears from the display.
  3. Select the desired mode: Use the mode button to select the desired shooting mode, such as Single Shot, Aperture Priority, Shutter Priority, etc.
  4. Take the picture: Once you've selected the desired mode, you can take the picture by pressing the shutter release button.
1/24/2023 8:21:24 AM • Leica Cameras • Answered on Jan 24, 2023
How to get the Leica D-Lux 3 OUT of the Continuous Mode? The answer is NOT in the Instruction Manual. Thanks.
To exit the continuous mode on your Leica D-Lux 3 camera, you can follow these steps:
  1. Turn on your camera and select the shooting mode by rotating the mode dial to the appropriate setting (e.g. P, A, S, M)
  2. Press the menu button and navigate to the "Drive" or "Continuous" setting.
  3. Select "Single" or "Single Shot" mode to exit the continuous mode.
  4. Press the menu button again to exit the menu and return to the shooting screen.
Alternatively, some cameras have a dedicated button or switch to switch between single and continuous mode, in that case you can use that button/switch to switch modes. It's also important to check the manual of your specific camera model, as the steps may vary depending on the camera firmware version and the model itself.
1/24/2023 1:28:37 AM • Leica Cameras • Answered on Jan 24, 2023
When turned on my Leica D-Lux 3 immediately goes to the Continuous Mode.
It sounds like the Continuous Mode is set as the default setting for your Leica D-Lux 3 camera. To change the default mode, you can consult the camera's manual for instructions on how to navigate the camera's menu and change the default setting to a different mode such as single shot or aperture priority.
1/22/2023 3:23:06 PM • Leica Cameras • Answered on Jan 22, 2023
How to replacing flash Leica AF-C1?
Welcome to Fixya Christopher. The Leica is such a good camera, I would entrust repair to a local Leica service centre, despite it being a point and shoot. Someone is selling one on eBay for $500! Did you try replacing the batteries? Leica Parts right down at the bottom. https://www.psaparts.co.uk/digital-camera/leica/af-c1-battery--fe3r5n.html
Lomopedia: Leica AF-C1 - Lomography
https://www.lomography.com > magazine > 283418-lo... Straight up, the Leica AF-C1 is a compact 35 mm autofocus camera that shoots crisp photos with its two switchable lenses. ... The AF-C1 is not to be confused with ...
Leica C1 Film Cameras for sale ' eBay
https://www.ebay.ca > ... > Film Cameras Get the best deal for Leica C1 Film Cameras from the largest online ... ? N.MINT w/Strap ? Leica AF-C1 AF C1 35mm Point & Shoot Film Camera From Japan.
50mm f2 lens - Etsy
https://www.etsy.com > listing > leica-af-c1-with-2840-... Leica AF-C1 with 2.8/40 - 5.6/80 lens Compact Point and Shoot 35mm Film Camera Fully Working, Used cosmetic condition Lens is totally clean, no scratch or ... Rating: 4.8 · ‎129 votes
Leica AF -C1 instruction manual, user manual, free PDF ...
https://www.butkus.org > chinon > leica > leica_af-c1 Leica AF-C1 Posted 12-23-'06. Link to Leica C1 film camera. The next page contains information on this camera. If the image below looks like your camera,
AF-C1 - Leica Wiki (English)
https://www.l-camera-forum.com > index.php > AF-C1 Jan 16, 2015 - AF-C1 ... Type - Compact film point-and-shoot view-finder camera. ... Autofocus system - Active multi-beam infrared autofocus with focus memory and ...
Leica AF-C1 (the 1st point and shoot camera from Leica) ' Flickr
https://www.flickr.com > groups The Leica AF-C1 is the first compact point and shoot camera from Leica. This group is for everyone who made photos with the Leica AF-C1 and to discus about ... LEICA PARTS
Leica Parts and Technical Support Department
https://leicacamerausa.com > pages > contact-technical-s... LEICA ANNOUNCEMENT · Our Technical Support Department can answer your technical questions regarding our products and ordering spare parts. Get help from the ...
1/15/2022 10:54:28 AM • Leica Cameras • Answered on Jan 15, 2022
Lumix leica DMCTZ35. Warning message : "This memory card is write protected" What can i do to get rid of it ? I cannot use the camera.
I dont know what type of card you talking about.
For example SD cards have small lever and moving it allows going from write protecting mode to full access
5/17/2020 7:51:01 PM • Leica Cameras • Answered on May 17, 2020
2answers
I need puk for leica ts09 puls 1359271
Eric Vangsness
Machine Control Specialist
Fargo, ND Area
Office: 701-237-3333
Mobile: 701-866-3688
9/1/2019 6:09:20 AM • Leica Cameras • Answered on Sep 01, 2019
What is error 85 in Leica TC 307
This is not a camera. Please repost in a more appropriate forum, where you may find someone with experience of this equipment who can help you.
7/22/2019 7:08:38 PM • Leica Cameras • Answered on Jul 22, 2019
Need for leica Ts02 Total Station Puk S.No 1358998
You have posted this statement on numerous occasions in varying forums. Please, either ask a question stating what you require, or refrain from posting. Thank you.
7/20/2019 7:50:07 PM • Leica Cameras • Answered on Jul 20, 2019
Need Puk Leica Total Station Ts 02 S.No 1358998
No idea what this is, or why you have told us what you need, but try Google for information
7/19/2019 10:06:21 AM • Leica Cameras • Answered on Jul 19, 2019
I need puk for leica TS09
puk code does not provided by the phone or manufacturer. it is provided by your sim network. eather you have your sim casing to find it there or just ask your sim network's operator. anyways you can just simply request another sim with the same number.
(just buy it.)
5/12/2019 7:21:34 AM • Leica Cameras • Answered on May 12, 2019
What is error 85 in Leica TCR705
The answer is still the same
1/14/2019 6:30:51 PM • Leica Cameras • Answered on Jan 14, 2019
I have hundreds of pictures in my Leica C that I have already copied to computer. It is too bothersome to delete pictures one by one from the camera. How can I format the memory card?
Press the [ ] button while viewing a picture Use Up/Down arrow to select [Delete Multi]/[Delete All], and then press [MENU/SET] • Items can also be selected by turning the control dial. • You can select [All Delete Except Favorite] in [Delete All] if there are pictures that have been set as [Favorite] • A confirmation screen is displayed. Select [Yes] with the cursor buttons and then press [MENU/SET]
12/28/2018 4:41:54 PM • Leica Cameras • Answered on Dec 28, 2018
How do you do a factory reset for a Leica D-lux 7
Set camera NOT in auto mode. Go to menu. Find reset. Hold down on directional pad for a few secs. Restore appears
12/17/2018 6:28:59 AM • Leica Cameras • Answered on Dec 17, 2018
Leica D-Lux 4 Digital Camera Logo
11 questions posted
Top Leica Cameras Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Leica Camera Expert? Answer questions, earn points and help others
View Most Popular
Leica Cameras
  • Leica Cameras
Most Popular Question
conect usb pc
  • Cameras
