Press the [ ] button while viewing a picture
Use Up/Down arrow to select [Delete Multi]/[Delete All], and then press [MENU/SET]
• Items can also be selected by turning the control dial.
• You can select [All Delete Except Favorite] in [Delete All] if there are pictures that have been set as [Favorite]
• A confirmation screen is displayed. Select [Yes] with the cursor buttons and then press [MENU/SET]
SOURCE: kodak easyshare cx6200 memory card requires formatting
If you have a card reader, try one of these memory card recovery programs: http://www.freedownloadscenter.com/Best/recover-sd-card.html
SOURCE: KODAK EASYSHARE Z710 DIGITAL CAMERA
Hi Tanya
It sounds like something was corrupted when you transferred your pictures to the computer.
If you have all the pictures safely on your computer, it will be ok to reformat the memory card and then just copy and paste the pictures back to the card.
Insert the card in your card reader, go to My Computer, you should be able to see the card as a removable drive. You can click and open it just like a folder and see what is on the card.
I would also back up the pictures to an external drive or dvd so they are extra safe!
SOURCE: I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Testimonial: "Thank you for quick reliable service!"
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
SOURCE: When you get memory card error on every card you
You said it in the last seven words "deleted the pictures off the memory cards" Once the pictures have been downloaded to the computer Hard Drive you need to Format the memory card. Formatting a memory card is done in the camera it is to be used which brings it back to a clean surface and compatibility. Your manual said that "normally" formatting isn't necessary which is a pile the bull left behind. I could go into detail as to why format but I'm trying to keep this short/
Here is a diagram to show you where the "format" menus is and what to do with it.
Diagram
Cheers
