20 Most Recent Swanstone KSLS-3322 Double Bowl Kitchen Sink, Black Galaxy Questions & Answers
0answers
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.Clean out drain line under sink, and bottom of disposal under cutter blade.Copy following link for clogged disposal, and drain line tips.http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/1/2012 1:22:17 AM • Swanstone... • Answered on Nov 01, 2012
How would the swanstone kssb-3322-015
They will always look great with any back ground of counter top due to their unique look and under slab mounting.........Great choice........Hope this helps.
4/20/2011 7:06:35 AM • Swanstone... • Answered on Apr 20, 2011
Can a swanstone sink be resurfaced? After almost
yea you can try to put bleach on it and let it sit for awile.
3/1/2011 2:57:58 PM • Swanstone... • Answered on Mar 01, 2011
The hold downs on the bottom of the sink do not
Depending on the material that your counter top is made out of there are several options.If it is wood composite with a laminate covering you can mark the location of each hold down with the sink in place then remove the sink. Carefully use a high speep drill bit to drill a series of holes at each location beingcautious to stop at least a 1/4 inch less then the minimum depth required for clamps and then use a very sharp wood chisel by hand to remove material to fit.
If your countertop is corian or other man made composite you can use pure silicone caulking as it is an excellent adhesive when cured.It will take a minimum of 24 hours to set and 7 days to cure. You will need to be careful if you use silicone because it needs to have all excess cleaned up in a hurry or it will be difficult to clean . If you have a pretty good fit between sink and counter top I would use just spot applications and try to leave room for finish caulking after silicon cures. I use a product called polyseamseal for final caulking as it is latex base and you can get a very nice finish and it cleans up eassily. It is also a good adhesive when it cures.
Check manufactures recommendations as several will only honor warrenty if silicone is used. I hope this helps you. Thanks
1/14/2011 3:46:31 PM • Swanstone... • Answered on Jan 14, 2011
I have a lovely Swanstone kitchen sink that got a
if the filler can be easily removed then it wasn't cleaned and dried properly.
try it again, be sure to remove ALL the sanding dust from the surface and inside the chipped area.
be sure to get the correct color, some colrs are close, but slightly different when dry
8/15/2010 6:40:13 AM • Swanstone... • Answered on Aug 15, 2010
Drilling holes/mistakesr
Yes they do you can also get fill cap at hardware stores.
5/1/2009 12:35:19 PM • Swanstone... • Answered on May 01, 2009
2answers
If I tip a drinking glass over on a swanstone counter, will the glass break
115 Rockwell R Scale, 42 Barcol you can google these specs for more info
12/28/2022 8:08:38 PM • Swanstone Home • Answered on Dec 28, 2022
Should swanstone vanity top be sealed with tile/grout sealer
no it does not need it
8/28/2018 1:43:29 AM • Swanstone Home • Answered on Aug 28, 2018
I inadvertently place a hot pot in my swan stone sink. I small portion melted the sink. Seems like a touch up paint would be the answer. Is there such a product?l
https://www.swanstone.com/index.php?page=faq It can be sanded. That pot must have been really hot to cause damage. See if this link helps. Without seeing a pic I can't advise further. Good luck!
8/31/2016 7:48:31 PM • Swanstone Home • Answered on Aug 31, 2016
0answers
0answers
Swanstone sink with chip near
Unfortunately Swanstone does not have a repair kit for this type of damage. The chip will be permanant. They do offer a limited lifetime warranty which if a defect is found they will repair or replace at their discretion. Of course you will be responsible for any labour cost as per their warranty and they do not go into any detail on how to repair impact damage. For more information go to www.theswancorp.com
1/28/2014 6:58:11 PM • Swanstone Home • Answered on Jan 28, 2014
0answers
Counter cracks
Be the first to answer 10/24/2013 4:53:07 PM • Swanstone Home • Posted on Oct 24, 2013Be the first to answer
After installing shower wall panels
Just keeping it clean.
9/11/2010 2:38:55 AM • Swanstone Home • Answered on Sep 11, 2010
Hairline cracks on top edge of swanstone bone laundry sink
try tub and tile epoxy at home depot
3/27/2009 5:49:36 PM • Swanstone Home • Answered on Mar 27, 2009
Swanstone KSLS-3322 Double Bowl Kitchen Sink, Black Galaxy Logo
Popular Tags
9 questions posted
Top Swanstone Home Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Swanstone Home Expert? Answer questions, earn points and help others
View Most Popular
Swanstone Home
  • Swanstone Home
Most Popular Question
bought new kitchen sink pipes garbage
  • Home
