If I tip a drinking glass over on a swanstone counter, will the glass break
If I substitute "granite" or "tile" for swanstone, my experience say the answer is likely yes. On the other hand, with solid surface acrylic like Corian, the answer is likely no. So where is swanstone on the "hardness spectrum?
Top Expert:
An expert that got 20 achievements.
An expert that got 10 achievements.
Swanstone Master
Re:
It is the same as Corian. Also it depends on the glass.
What is Swanstone made of?
What is the Swanstone material? This product is manufactured from our solid surface material, Swanstone, which is a compression-molded, thermoset material consisting of a blend of polymer resins, fillers and reinforcement additives.
Glass tiles can easily be cleaned with a mixture of equal parts of water and vinegar. If you put this solution in a spray bottle, it is easy to apply to the glass tile surface. After spraying, allow the mixture to sit for about ten minutes, so that the vinegar has a chance to work on the hard mineral deposits. Then, a soft bristle brush can be used to not only clean the surface of the glass tiles, but also to scrub the grout.
Your not troweling enough glass thinset onto the wall. The thinset should be creamy and troweled evenly most people hold the trowel to flat or use to small of a trowel you also could lightly coat the back do the tile to give it a good mechanical bond
i have been installing these kind of counter tops for years,there's a ton of stuff you can buy to seal,and protect your counter, one trick is to apply mop and glow to a dry counter let it dry and apply more coats.the good thing about mop & glow is you can remove easy, it works great.good luck
