20 Most Recent
Precision Camera Torque Angle Meter/gauge For Head Bolts And More 28100 Questions & Answers
What are the torque specs for the head bolts on a
They are torque to beaking point (torque to yield) and they are supposed to be replaced. They started that in 96 when GM realized they weren't selling enough parts along with the switch to plastic intake gaskets that leaked from day one. FWIW on a pre 96 the head bolts torqued to 65 ft lbs. The rockers don't torque, they provide the proper valve lash adjustment. Valve lash is zero.
Head Bolt Tork 1989 351 windsor 5.8L
Main cap bots
95-105 ft.-lbs.
Connecting rod bolts
40-45 ft.-lbs
Cylinder head bolts (follow factory torque sequence)
90-100 ft.-lbs.
Rocker arms
17-23 ft.-lbs.
Intake manifold bolts
23-25 ft.-lbs.
Oil pump bolt
23-28 ft.-lbs.
Cam bolts
40-45 ft.-lbs.
Cam thrust plate bolts
8-10 ft.-lbs.
Harmonic damper bolt
70-90 ft.-lbs.
Flywheel/ flexplate bolts
75-85 ft.-lbs.
Pressure plate bolts
35 ft.-lbs.
Front cover bolts
12-15 ft.-lbThis is according to the Classic Truck website.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
