20 Most Recent
RTO Blower Motor,1.5HP,110V,Radial Questions & Answers
How do i fix a blower motor in my 2001 dodge
2001 are a pain, there is a hidden screw that you have to remove the top dash board and the passenger side speaker and try and fish a 1/4 inch extension down down there with 2 swivels to get, if your blower motor only works on high i suggest trying just to replace the resistor first.
Front blower not working on my 2001 Dodge grand
Disconnect the negative battery cable.
Disconnect the blower motor lead connector from the wiring harness connector.
Remove the blower motor cooling tube from the blower motor.
Remove the four retaining screws.
Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
Lift up on the blower and remove it from the blower housing.
Installation the new blower motor by reversing the removal steps.
Connect the negative battery cable.
WHERE THE BLOWER IS LOCATED ON A 2002 L200
Its located in the cowl where the windshield wiper motor is. Almost in the center. you have to first remove the wiper arms then remove the plastic cover, then take the wiper trans out . you should seeit then. remove the cover and pull unit out but dont forget to reseal cover when reinstalling or you could develop leaks.
Stops running after warms up
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
11/22/2013 10:43:17 AM •
RTO Garden
Answered
on Nov 22, 2013
