where was the motor to be used so it needed a cover, health and safety issue only the moving parts that can trap your fingures or grab your hair need to be covered,and if made of steel they need to be earthed, other way to make was to hinge the cover from a base that is made to completely surround the motor and use 3 screws to secure or aslide bolt but you need to let the motor breathe as it will burn out or catch fire with the heat generated by the motor
Amazon.ca
https://www.amazon.ca > Fair-Oaks-Standard-Skimmer-...
Allows you to repair your rusted skimmer area without replacing entire pool. Pool walls are made of galvanized steel which will eventually rust. This repair ...
Rating: 4.7 · 137 reviews · $131.45 · In stock
Missing: Azteck ' Show results with: Azteck
Question edited for clarity.
Question moved from Computers category.
Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power.
https://www.google.com/search?q=lifesmart+ls350+plus+220+volt
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need.
That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on.
Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard.
https://www.google.com/search?q=Maax+461+Heater
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out.
So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
Question edited for clarity, spelling of maker and order of 'make model (what it is)'.
Question moved from Sewing Machines category.
It appears to be a New Zealand product made in Australia. We are in North America. This link should find you one and also has a link to the maker.
https://www.google.com/search?q=+leisurerite+GL2000+spa+replacement+cover
