20 Most Recent
Black & Decker Prestige Plus Premium X830 Iron Questions & Answers
The electrical cord is very
mcdevito75 here, You may have a problem with the heating element in your iron, Check to see if you have a Warrantee if so, return the iron to Black & Decker. In the meantime look for an appliance repair shop in your area and have the iron checked out.
Why do people smoke
Managing unpleasant feelings such as stress, depression, loneliness, , and anxiety are some of the most common reasons why adults smoke. When you have a bad day, it can seem like cigarettes are your only friend. if you facing while quitting smoking then you can consult some good psychologist who can help you in this situation.
https://www.lybrate.com/indore/psychologist
How to Turn black & decker iron on
at the temp control switch or at the wall socket
if the control switch makes no difference and the wall socket has power , junk the iron
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
How do I dissasemble a black & decker iron
Unfortunately many domestic irons are assembled with glued joins and one-way plastic clips, as the cost of labour and materials makes most of them uneconomical to repair, so you are not meant to.
Without knowing the model number of it that's as much as I can tell you.
