20 Most Recent Casio Exilim Zoom EX-Z250 Digital Camera Questions & Answers
I have and love my
Try the procedures listed here.
1/28/2013 6:52:13 PM • Casio Exilim... • Answered on Jan 28, 2013
Write Protection Removing
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/24/2012 6:33:34 PM • Casio Exilim... • Answered on Sep 24, 2012
How do i unlock my sandisk?
You neglected to specify the type of memory card, so I'm going to assume it's an SD or SDHC card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/7/2012 9:14:08 PM • Casio Exilim... • Answered on Sep 07, 2012
My casio exilim cant open the lens anymore.I think
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
If these don't work, you'll need to contact the support section of the Casio website for their advice. Get an estimate for repairs....then decide if you want it fixed or replaced.
4/27/2011 9:41:30 PM • Casio Exilim... • Answered on Apr 27, 2011
Lens error appearing
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 12:45:12 PM • Casio Exilim... • Answered on Sep 30, 2010
Hello, we have a caso exilim zoom ex-z250
Hello
Regards
Andrea
9/27/2010 5:21:29 PM • Casio Exilim... • Answered on Sep 27, 2010
I'm getting a lens 2 error message when I turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/24/2010 9:03:33 PM • Casio Exilim... • Answered on Aug 24, 2010
My Casio Ex-fc100 is starting
Visit to the given link In the following link select your region then visit support page then select driver or downloads and select your product if new version has been launched then you will get there... http://world.casio.com/
For more information visit to the given link and search by "firmware"... http://www.analysisprogram.com/wordpress/index.php/2009/04/14/casio-high-speed-exilim-ex-fc-100-review/
... Hope this has helped you... Thanks...
7/29/2010 9:09:11 AM • Casio Exilim... • Answered on Jul 29, 2010
My casio EX-Z250 as been accidently dropped onto a
Sounds like the lens could have been slightly tweaked, making it out of alignment just enough to not fully retract. You can try to GENTLY push it in the opposite direction to see if you can "reseat" it. If not, a service center is probably your best bet at this point...
10/21/2009 9:37:38 AM • Casio Exilim... • Answered on Oct 21, 2009
Need instructions manual to casio Exilim digital camera Ex S8 12.1 pixels
Look it up on Google
9/16/2019 6:06:50 PM • Casio Exilim... • Answered on Sep 16, 2019
How do I identify my casio camera`s model by using the serial number?
The quickest way is to put the serial number into your search engine. To double check yourself, look thru the images until you see a picture of the camera you own.
8/16/2016 9:03:54 PM • Casio Exilim... • Answered on Aug 16, 2016
Instructions on operation
Digital Cameras - Manuals - CASIO
support.casio.com > Support > Manuals
CasioIn order to use this service to download user's guides and operating instructions (manuals), you must agree to be bound by the following "Terms and Conditions.
Manuals - Support - CASIO
User Manual for Casio Watch Module - My G-Shock
12/28/2015 1:03:33 AM • Casio Exilim... • Answered on Dec 28, 2015
0perating instruction
[PDF]Operation Guide 5410 - Support - Casio
support.casio.com/en/manual/009/qw5410.pdf
CasioThis User's Guide uses numbers shown above to identify watch hands and ..... follow the instructions in this manual, especially the information under "Operating ...
12/28/2015 1:02:43 AM • Casio Exilim... • Answered on Dec 28, 2015
I am asking anyone who has firmware for casio ex z40, to help me clear the system error. please send it to me to my email address([email protected])
Sorry, we don't send e-mails. Only when you have the right tools and software to flash a camera from Casio, you could use firmware. You can't put in there firmware, when the camera is not 100% functional. Once the flashing of the new firmware starts, it can't be stopped, because it is writing new software that has no connection with the older software. And a part of the old with a part of the new software does not make one correct program. So NEVER try to solve a system error with a update. The system error must be repaired by a pro.
3/5/2015 9:57:59 PM • Casio Exilim... • Answered on Mar 05, 2015
How do i unlock the card on my exilim.casio camera
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
2/27/2015 1:24:51 PM • Casio Exilim... • Answered on Feb 27, 2015
I need to replace the battery cover for my Casio EX-Z60
Good luck with this. Casio doesn't sell parts. Try Ebay.
12/6/2014 5:01:05 AM • Casio Exilim... • Answered on Dec 06, 2014
0answers
Casio Exilim Zoom EX-Z250 Digital Camera Logo
Popular Tags
12 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
write protection removing
  • Cameras
