20 Most Recent
Cub Cadet I1042 42" 18HP Zero Turn Tractor - ZTT42 Questions & Answers
Lack of power
I had the same problem with my 2011 i1042. Turned out to be drive belt not snug enough. Installed new drive belt all OK now - plenty of power & speed, no slipping. good luck. (BTW: it was a REAL PAIN to remove and replace the belt!)
Cub Cadet 1050 2014 model. The gas pedal locks in the down position until engaging the break.
If the gas pedal on your 2014 Cub Cadet 1050 model is locking in the down position until the brake is engaged, there may be an issue with the mower's safety interlock system. This system is designed to prevent accidental engagement of the blades when the operator is not in control. Check for any debris or obstructions around the pedal mechanism and the brake system. Additionally, inspect the safety interlock switches near the brake pedal for proper function. If the issue persists, it's recommended to consult the owner's manual for troubleshooting steps or seek assistance from a qualified Cub Cadet service professional to ensure safe and proper operation.
Cub cadet chipper shredder starter coil is locked - will not pull
Recoil starter is locked?Remove spark plug to be sure engine hasn't hydrolocked with fuel and/or check crankcase oil level. If excessively high oil level then likely crankcase and cylinder is full of fuel from a stuck carburetor fuel inlet needle valve.If cylinder is clear of fuel/oil then remove recoil starter and see if recoil is functional and engine will rotate by hand.
Cub cadet lxt 1046 throttle cable how to change
For the most accurate and up-to-date information, I recommend consulting the official Cub Cadet LXT 1046 operator's manual. The manual typically includes detailed instructions on maintenance procedures, including how to replace components like the throttle cable.
