20 Most Recent
Sunbeam Grill Series 460 Questions & Answers
How do i replace my sunbeam grillmaster regulator?
the problem is going to be the QCC handwheel or it is the o-ring in the tank. if you're swapping tanks instead of refilling, get a new tank but before attaching it turn the bbq on without a tank attached. leave it on for a few minutes so any residual pressure dissipates into the atmosphere. turn everything off, attach the regulator and turn the tank on very slowly before lighting the grill. the QCC handwheel can be problematic although it is rare. You can replace it with the older style POL connection which is a more reliable connection for the LP cylinder. Simply trace the gas line from the regulator to the manifold and unscrew it. the connection is a 3/8" flare which means you do not need putty or tape, just replace the gas hose and regulator as tight as possible. pressurize the line and pour soapy water on it to make sure it is not leaking.
