20 Most Recent Sunbeam Grill Series 540 Questions & Answers
Check regulator
Sunbeam Grill... | Answered on Feb 24, 2018
usually those shields go over the top of the burner to prevent food from plugging the holes .
Sunbeam Grill... | Answered on Nov 03, 2017
If this is a propane (LP) grill, try replacing the regulator and hose that goes to the tank. It sounds like the grill is not getting enough gas.
Sunbeam Grill... | Answered on Jul 20, 2011
most gas grills do cant speack specifically for this one but i dont think i have ever seen one that doesnt come apart
Sunbeam Grill... | Answered on Oct 30, 2009
www.grillstuff.com please rate me if this was any help..good luck!!
Sunbeam Grill... | Answered on Jul 21, 2009
the temp range should be in the instructions
Sunbeam Grilling | Answered on Apr 22, 2015
the problem is going to be the QCC handwheel or it is the o-ring in the tank. if you're swapping tanks instead of refilling, get a new tank but before attaching it turn the bbq on without a tank attached. leave it on for a few minutes so any residual pressure dissipates into the atmosphere. turn everything off, attach the regulator and turn the tank on very slowly before lighting the grill. the QCC handwheel can be problematic although it is rare. You can replace it with the older style POL connection which is a more reliable connection for the LP cylinder. Simply trace the gas line from the regulator to the manifold and unscrew it. the connection is a 3/8" flare which means you do not need putty or tape, just replace the gas hose and regulator as tight as possible. pressurize the line and pour soapy water on it to make sure it is not leaking.
Sunbeam Grilling | Answered on Mar 15, 2014
Grilling Logo
14 questions posted
Top Sunbeam Grilling Experts
Gil Shultz
David White
Steve Pack
Steve Pack
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Grilling
  • Sunbeam Grilling
Most Popular Question
no gas
  • Grilling
