thank u very much. listen u nokia 6600 r gradually some slow system for it ram & processor. so it happen. but there are many reason for slowing such if u install loady and many application and the other things is if it memory contain virus. for it plz unstall unnessary application. and if u want parmently solution then u need format ur phone. its way is use *#7370#. and other way switch off ur phone and then press together these buttomn send key +*+3+ power button. it will be solved
sir your cellphone has been hacked. I will advice you to go to nearby nokia shop and tell them to change the software of your phone. It will cost you around 10-15$. thankyou for using fixya dont forget to rate the solution
it simple man,reformat ur celphone anddont use theold memorycard try to use ur cp without memory card itworks i have the same problem. 1.reformat ur cp 2.dont use ur old mem.card this is my email [email protected]
It is necessary to format your phone, because system files regarding your phone boot sector seems got corrupted. There is not enough room in your RAM it leads to your phone at this status. Take important data backup, remove MMC and enter the press four keys i.e. 3.*,green send key and power on key together for sometime and hold it for sometime. Your phone screen will indicate "FORMATING". Your phone will get formatted, then switch off and on it again as usual . Remember to scan your MMC with a good anti virus before inserting it back in phone. During formating don't remove battery and do this process only with enough charged battery. You will be able to send your message then. Do vote this solution....
