Sony Ericsson Z310i Cellular Phone Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone turns on but the screen inside is black - the time still shows on the front. Is something that can be fixed. Thank you
Christopher Lozada
Level 3:
  • Master 1,140 Answers
  • Posted on Jul 24, 2011
Christopher Lozada
Master
Level 3:
Answers
1140
Questions
0
Helped
276888
Points
3978
Common problem of this phone is the flex connector that meets the upper and lower panel.flex cable are not repairable,indeed it can be replace with a new one.i think you need to bring your phone to a service center.it is more safe if somebody with knowledge will fix this problem,might broke or damage some parts and accessories.
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 • Cell Phones
When i open my phone the inside screen does not display anything its black. the front screen is fine but not the inside screen, the inside one has no display. how can i fix it?
Hi this is a very common problem with all flip and slide phones and even laptops and notebooks, the problem is to do with the data ribbon that connects the screen to the circuit board in the bottom of the phone.
now inside this ribbon are several single strand copper wires and over time open and closing the phone causes these to break and you then lose the connection with the screen.
as this is such a common fault it makes the part itself cheap to buy and cheap to get fitted. it isnt something you can do your self as you need specialist tools to take the phone apart and to fit the data ribbon.
if you want it repaired the cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it whilst you wait or the next day at the latest.
its up to you if you think the phone is worth getting fixed then it wont cost much to get done.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks,,,..
Dec 15, 2010 • Cell Phones
1helpful
EnV front screen has a black stripe
Its manufacturing fault which can be caused at any time while using or if it get hurts .. you can calaim its warranty or take it to near by mobile shop to get it fix .. they might change screen or the serial wire of screen
Dropped Env2, Screen wont show up
Well, its possible that you just need to turn the phone off, and turn it back on. Or maybe when you dropped it, something inside the screen itself broke.The only way to be sure is to take it in and have them look at it. Good luck.
Really weird white/black screen
it may be a battery or an lcd problem. you may need to replace a part. pay this forum page a visit: http://modmymoto.com and see if someone can answer your question there.
Screen Problems
You need to take the phone to a repair shop and have them replaced the lcd for you...
8helpful
27answers
Blank screen
Seriously, bang the phone sideways on a desk, it works! Do it on each side 2 or 3 times, then back again. Don't slam it down, but bang it a couple times I'm not kidding at all
Front screen wont show time
hold any of the buttons on the side for a second or 2, and it comes on.
Front screen not displaying anything
I would go back to where you replaced the front screen and let them know that they did not fix the problem. Let me know what happens. No easy way to fix.
Cynthia
Front Display
This seems to be a common problem. The same thing happened to me about 8 months ago. I'm still using the same phone, and I even have to carry around a list of contacts just so I can call people. I brought the phone into the Verizon store and they claimed it was water damage. The little water damage sticker thing didn't show that it was water damage, but they said there was corrosion inside the phone. I still don't believe that it was water damage, considering the number of people that had the same exact problem. I get to upgrade soon though, and I've learned my lesson - I'm getting the full coverage insurance. Just so they don't try to say it was water damage again, if anything happens, I'm just going to say it was stolen.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
