Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug. Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
"It won't do anything" means that there are no dash lights, no buzzers, nothing?
Any car has very slight electrical drains when it is shut off. For one thing, the clock is running, but there are a number of other tiny loads as well. With a good battery, you should be able to park a car for six months to a year and still start it.
However, if you start the car several times without running it long enough to recharge the battery, or if the drain is larger than it should be due to electrical problems or aftermarket accessories, you can get a failure to start.
Unfortunately, maintanence-free batteries don't tolerate being run completely dead very well, and many owners have unhappily found that draining an older battery once or twice was the last straw that ended their battery's life.
I suggest that you borrow a charger or a set of jumper cables to start the car, and drive it 30 minutes or so to fully charge the battery. If you have more problems, get the battery load tested at a shop that sells batteries to see if it is still OK.
If you have not been putting gas treatment in your gas to treat the ethenol they have been putting into the gas its a good chance its the needle valve in the carborator. If you live in a state that does not add ethenol to the gas disregard this advise.
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
if the battery is ok why do you need to jump anyway? most likely its not ok, the alternator do not provide enough power at idle to supply the engine the amount of power needed to keep it running,below 1200rpm you actually use the battery, in the range of 1400 to 2000rpm the alternator will produce a surplus enough to recharge the battery, but if the battery is old it does not recharge enough to start your truck
