If your Roku is working properly, and will not connect to Netflix. Access your Netflix account through the internet on your home computer. Check the size of your instant que and if over 50 entry's, start deleting your que. The Roku can not handle over 50.
Fix Netflix not working on Roku
For Roku media players, here is the means by which to fix the Error code in the Netflix add-on. Since you can't free the stores from the gadget, the best way to fix "not running on Roku" is basically to do the accompanying.
Check if your system interface isn't working or separated
Check whether the Roku media requires an update. The Roku application update, in the interim, consequently scans for an overhaul at an interim of max. 36 hours. Here is the means by which to check "Home > Settings > Device > Software Update > Search Now" for updates to the Roku application.
Restart Roku after a positive update
Log out of and sign in to your Netflix account once more. At the point when your membership lapses you will most likely be unable to clear the Error code until your membership is recharged.
Source URL : https://www.rokuerrorcode009.com/netflix-not-working-on-roku/
not able to sign up other channels than netflix
I have tried unplugging and resetting numerous times, but will not access the programs I select on Netflix. All the other apps work fine on Roku
netflix went out. hulu still worked. wth? reset roku, took out batteries to pair roku with remote. lights on box ok. tv stuck on which language. appears to be remote but remote from other roku does'nt do anything either. bought both boxes 4 months ago. i'm thinking they're junk. i gotta have roku. what about roku stick or whatever that thing is or maybe chromecast
