Model R-9500 has been discontinued for several years. It is very possible that the batteries are dead because they are so old. You may need to replace them. You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
