Hello and welcome to FixYa!
Have you tried swapping the PCM? It may have busted capacitor that's why the maf is not working properly. Please do check the PCM for burn, you may need a PCM replacement just incase it's faulty.
Please keep me posted on the progress.
Have a good one and thank you for using FixYa!
they put it on there scanner, if i take neg then pos battery off put back on pos then neg,,reset pcm it works for a bit the theres power lost. I was told theres a short in the ground, its one single wire ,,tan and blue going straight to pcm. the red goes everywhere,,but with key on red wire give 12 volts. the black,,power ground breaks off and is kinda hard to check under manifold i tried just putting the power ground new wire right to good ground but i think theres a problem somewhere along the way?
maf is good, power to it is good, restart pcm then after a while it looses it
ok theres 4 wires goin to maf, blue,,signal, tan ,,ground,,black,,power ground and red main p0ower.with meter in signal wire and ground to chasis, when it starts acting up it jumps from.65 volts which its suppose to be ,, to at times battery voltage..12, 14 which is to much
