Daewoo KOC-925T Microwave Oven Logo
Posted on Feb 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a synchro motor shaft (semi circle shaft with square drive) model number Daewoo First edition oven model numberKOC 970T Supalek s/n 4414D70A50 s/n KJ7XAC0215 the motor serial number looks like GM-16-24FD 7912 C
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Feb 23, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263306
Points
2023
The plate is not turning
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need.
If the model number is correct, the part number for a replacement motor is WB26X10038. You may also check the turntable shaft to make sure it is not stripped and slipping on the motor shaft. The part number for the turntable shaft is WB06X10138.
If you have any questions, please post back and let me know. I hope this helps you.
Turntable does not turn and the wheel underneath makes grinding sound
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
repairclinic.com
If the model number is correct, the part number for a replacement motor is WB26X10135. You may also check the turntable shaft to make sure it is not stripped and slipping on the motor shaft. The part number for the turntable shaft is WB06X10564.
1helpful
My above the range Maytag Microwave oven plate does not rotate. Bought a new rotator wheel as the old one was broken, and the central spindle will rotate, but not with the plate on it. What can I do?
The spindle (called a turntable shaft) sits atop a small motor shaft from the turntable motor. You either have a weak turntable motor, stripped shaft (which allows the motor shaft to free spin when it has any weight on it), or both.
The turntable motor is located under the bottom panel of the microwave oven. You do not have to uninstall the oven for this repair.
First, unplug the unit, remove the glass carousel tray, and pull straight up on the turntable shaft to remove it. Next, locate and remove the series of screws along the bottom panel underneath the oven. The bottom panel will open exposing the drive motor. The motor comes out by disconnecting the connector plug and a couple of mounting screws.
If the model number you have this listed under is correct, you can view these parts at searspartsdirect.com. Locate items 11 (turntable motor) and 14 (shaft) under the "Cavity" heading. Other sites you may try are pcappliancerepair.com, appliancepartspros.com or repairclinic.com to see if you can find these parts any cheaper.
If you have any questions, please let me know. I hope you find this information helpful.
Turntable has suddenly stopped working.
The turntable motor may be bad, if you've confirmed the switch is working. The motor is located under the bottom of the microwave and has the shaft penetrating through the bottom of the oven cavity with a drive coupler attached. The coupler is what drives the glass carousel tray. The motor can be accessed by unplugging the microwave and removing the bottom panel screws. The motor is held in by a couple of screws and two connecting wires. The coupler will lift up and pull off the motor shaft from inside the oven.
You can view this part and exploded view diagrams of your microwave at appliancepartspros.com. Just type in your model number and look under the "Magnetron and Air Flow" heading for item 6 (part number AP 3119645).
If you have any questions, please let me know. I hope this helps you.
Micro wave works but do not heat up the contens model koc 970t
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Daewoo KOR 1B4H microwave light bulb burnt out. Can I change this myself?
It probably is, but I cannot find your model number on the Daewoo website to look in the manual.
Please confirm and reply the model number .
Turntable
There's a small turntable motor under the bottom panel of the oven. You can access it by removing the series of screws holding this bottom panel in place underneath the oven. You either have a motor that is failing, or the turntable shaft which the carousel rides on, might worn and starting to slip on the motor shaft. The motor is held in with a fews screws and has an electrical connection you will need to unplug. The turntable shaft simply pulls off the shaft from this inside of the oven. I hope this helps you. Let me know if you require addtional assistance.
PS For future reference, please post your make and model number as all microwave ovens are not made the same and can exhibit different symptoms.
GE advantium SCA2001FSS
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
2answers
Need a service centre
Can u suggest a service center for a daewoo microwave oven at bangalore. I wanted a glass turntable for my daewoo microwave oven. I wanted its telephone or contact number.My daewoo mocrowave oven MODEL NO.KOC-8H4T. Pls reply soon
Top Daewoo Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
