Hi, The Standby/Power light of
the TV blinks when there is any internal malfunction in the TV. The Lamp light
blinks when the Lamp requires replacement. If the television is plugged
into a power strip or surge protector, remove it from the power strip or surge
protector and plug it directly into the wall outlet. If the issue is resolved,
the problem is with the power strip or surge protector and not the television. If the issue continues to
occur, service may be required. Thanks for using Fixya.
The self-diagnostic function of the projection TV will cause the STANDBY light
to blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue. As per the two examples
below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not
securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating.
To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the
flash sequence is not listed above or the light continues to flash, follow the
steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
