Hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Testimonial: "Thankyou!great service!Thumbs up!"
If you are having problems with your video card
the drivers might not be installed correctly you might
have to uninstall the graphics card restart your computer then reinstall the
graphics card and its drivers
If your computer
came with a motherboard disc the drivers could be on it
Click start control
panel administrive tools computer management device manager scroll to display
adapters + to expand you might see a yellow question mark ? or exclamation mark
! or a red x right click select reinstall drivers or
you might need to
download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package
supports the following driver models:
Hope this helps
you
This would be helpful if i had onboard video,as i dont,this graphics card refuses to be detected,and is causing alot of problems,so i had to uninstall it and re-install my old one,and the old one was detected straight away,slots on the( his) card are different.Three notches,instead of one.
