Peavey Kb 2 Keyboard Amplifier Logo
Posted on Apr 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
Fred Yearian
Level 3:
  • Peavey Master 5,603 Answers
  • Posted on Apr 27, 2011
Fred Yearian
Peavey Master
Level 3:
Answers
5603
Questions
Helped
2250578
Points
16163
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
How can I set up my mackie 1402 mixer so I can have (2) monitor mixes
This unit has 2 AUX sends, both of which can be used as monitor mixes. The top controls on each channel determine the pre-fade level for each mix.
Conenct a cable from the AUX out (either 1 or 2) to an amp. The only restriction is that the level control is a knob rather than a slider.
If you have any other questions, please update this and I'll try to answer for you.
Dan
2answers
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
I need a new mains transformer for my Mackie 1402vlz3 mixer but can't locate on in the UK. NB 1402vlz, not 1202 vlz as per the product below. (Can't get 1402 on the categories). Where can I source one, or...
Your best bet is to contact Mackie directly for a distributor in the UK.
The contact information is listed below.
Dan
LOUD Technologies Europe PLC GENERAL CONTACT Unit 1 Century Point, Halifax Road. Cressex Business Park
High Wycombe, BUCKS, HP12 3SL, UK
Phone: + 44 (0) 1494 557 398
SALES Email: [email protected]
SERVICE Email: [email protected]
Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
1helpful
2answers
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
