Cars & Trucks Logo
Posted on Jul 02, 2017
I have a 2004 XK and when I open the door, the window goes down a little (as it is supposed to) and then rises back up to the closed position. This causes the door to refuse to close. To close the door, I must roll down the window a fraction. I have tried the re-set option listed here - to no effect. This happened one day when I was getting out of the car - it just happened with no explanation. Has anybody got any solutions?
FARROKH
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 25 Answers
  • Posted on Nov 30, 2017
FARROKH
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
25
Questions
0
Helped
6629
Points
50
1. roll drivers window all the way down and hold it till it clicks.now roll it up all the way and hold it till it clicks.
2. do same with passenger window.
now your windows should work properly.
good luck.
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: 2004 turbo convertible beetle
Try using the all windows up and down button (Drivers side on door), evidently after you change your battery this is the reset proceedure.
Anonymous
  • Posted on Mar 29, 2009
SOURCE: Jaguar XK8 Window Problem
Same thing has happened on mine!
The solution is to reprogram the window limits. You need to sit in the car with doors shut! Turn the key in ignition in position I or II, roll down the window all the way and keep holding the switch for 5 seconds, then roll the window up and again keep the switch pressed for 5 seconds, repeat same steps for other door.
Reprogramming is also described in the owners manual. I don't know how mine became deprogrammed, should only happen if the battery is disconnected!
Anonymous
  • 11896 Answers
  • Posted on May 25, 2009
SOURCE: Driver side window stuck on Nissan Maxima 2004
It is likely the window motor is wearing out and will need to be replaced. You can always try a different switch on those wires to rule out switch problem. Otherwise, the motor will have to be replaced.
Anonymous
  • Posted on Jan 18, 2010
SOURCE: 2006 Pontiac G6 GTP window auto close/open
OMG. I replaced the battery in my 06 G6 and had the same problem. the windows would not roll up or down how they did before. I read the answers on here and it does work. Hold up the window switch for ten seconds and it resets. You will have to do it to each window. Worked great. Thanks
Anonymous
  • 5 Answers
  • Posted on Aug 02, 2010
SOURCE: power sliding door will not stay closed. once
I have a 2006 SV6 with the power sliding doors. The problem that I found was with the contacts on the door ( They are called plungers) the movable pins were losing connection with the fixed part that the plungers slide thru. The plunger unit is very easy to replace if you can find one. The plungers are covered with a rubber cover and is held in place with 2 plastic pins. My Pontiac dealer could not even find one in his books, and claimed that he had never had anyone come with a door problem. My Chevy dealer said that it came with a wiring harness that is not needed for $154. The cure that I came up with was to take the plunger block apart (it snaps together)and replace the rusted out springs then solder 3" wires to the end of the plunger pins (they solder easy) to the tabs that go to the plug ( pop out the tabs to solder them or you will melt the plastic). It took about 45 min. now the doors work like new and will never loose contact
2001 Honda CR-V LX Temperature gauge rising
The ac fan only comes on when the ac is on , the engine fan comes on at engine operating temp . few things to check , the radiator core fins are free from rubbish leave or plastic bags , the thermostat is fully open , radiator tubes are blocked with gunk have it flow tested .
I have a 2004 XK and when I open the door, the window goes down a little (as it is supposed to) and then rises back up to the closed position. This causes the door to refuse to close. To close the door, I...
Hello
That usually happens when you have a loose regulator , which in effect would not set the window properly.
The regulator has to be in good condition for the setting to stay as it should be,
1helpful
2answers
When you open the door, the window drops a little and doesn't come back up until door closes normally, but my problem is when i open the door the window drops a little like its supposed to but instead of...
You may need to store the end position of the windows in the control unit. I would try the following, with the door closed, and the window partway open: Close the windows with the rocker switch ONCE. Then press the front half of the rocker switch again, this will store the end position in the control unit. Good luck!
My 2004 jeep grand cherokee has issues with windows rolling down and the automatic door locks.. Neither will work on any door. The sunroof will roll back however.
Had a similar problem... the wiring harness that goes inside the drivers door had a broken wire, hence no power would go to the door locks or the power windows. Check the area where the harness flexes when the door opens and closes.
2003 bmw z4. driver window does not drop 1/4 when opening or closing door. microswitch not in latch on body but inside door. how do I replace switch. thnak you
As long as it's not a mechanical malfunction, your car's position memory just needs to be reprogrammed. So, put the key in the ignition & place it in position 1 (ACC). Hold down the affected window switch for an additional five seconds after the window goes all the way down to perform a memory reset. Let this window back up, let go, pull the keys back out of the ignition, & open the door.
Jun 04, 2010 • 2003 BMW Z4
1999 xk top goes p and down but back windows
Your windows are a completely different component than your top so it might be a fuse.
1helpful
2004 JAGUAR XKR CONV. THE PASSENGER WINDOW GOES DOWN WHEN DOOR IS OPENED BUT ROLLS BACK UP WHEN THE DOOR HANDLE IS RELEASED. IS THERE A RESET OR IS THE LATCH FAILING
Voltage fluctuations with a weak battery etc can cause loss of window memory. Start car, lower windows and hold the switch down for several seconds then repeat in the raised position. This will reset window positon memory.
The driver's window lowers a little bit each time the door handle is pulled. The window is suppose to lower approx. 1" when you're opening the door to clear the convertible top but it won't raise back up...
Probably your battery is bad. either charge or replace that and then learn the windows again. (have you got your radio code before removing battery?) to learn the windows do them one at a time with door closed. hold the down button you hear a clck a few seconds after it opens fully now hold the up/close button and again wait for the click. easiest is to hold the button pressed for 10 secs after the windo has fully traveled down then send it up and again 10 secs after it stops moving.
Slow acting convertible top
your roof motors are in need of new carbon brushes and, one or, both motor pinion gears are partially stripped of teeth
3helpful
Window sensor drivers side
as far as the window goes... here is the full reset procedure. I beleve in your case you only need to do part #2
GLASS RESET PROCEDURE: If window is hindered whilst closing, it will open again immediately. Attention: does not work when using car key to open/close window. After window has opened, lift and hold appropriate switch within 10 seconds. If window is still hindered it will stop closing. After window has stopped, lift switch again within 5 seconds in order to close window. It will now close without roll-back function.
2. To reinstall this function: Lock vehicle from outside via driver’s door. When doing this, please ensure that all windows are completely closed. Unlock vehicle and then lock it again via driver’s door. Hold key in locking position for at least 1 second.
hope this help.
p.s. find a new dealership!!!
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
