SOURCE: hughes direct tv receiver (director pack)
get new ones i just had 2 boxes replaced 1 was sd-hbh and the other was a hi-def box both were fried cause the nit wit that set up the system didn't ground the dish and we got a lightning strike that fried them.... i would call direct tv or whoever your sat provider is because mine were replaced for free with 2 brand new boxes.... and you should check to see if your dish is grounded it will usually be grounded to a water pipe somewhere in the area of where your multi-switch is located
SOURCE: Hughes DirecTV TiVo SD-dvr80 quit working
the are some new features that tivo does not support. you still can watch your saved programs. Sadly the older tivos are equipped for the digital transitoins. I know Tivo and Directv are releasing a new receiver in a few months.
SOURCE: can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
SOURCE: How to connect a PS2 to a TV through a Hughes Direct TV box
unfortunately you cannot run a ps2 or any other device through the receivers. take a look at the tv may have inputs on the front or side of tv where you can use red/white/yellow cabling OR take a look at what type of cabling your tv does support and go from there. hope this helps.
SOURCE: hughes sd-dvr-80 rebooting randomly now stays on powering up when
This is common with drive problems.
Could also be a power supply getting hot.
