20 Most Recent Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver Questions & Answers
Call customer service and ask for compatible receivers at no cost since they upgraded your odu (outside dish unit) and left you with no service in 2 rooms. Let them know how upset you are and demand an answer to why the technician left you without SWiM compatible receivers in all the rooms. Call 800 531 5000 and request to speak with a supervisor. They have the authority to override. If customer service dept does not cooperate then ask to be transferred to the customer retention dept. You will get results there. Remember you are the customer not them. Good luck!
Hughes HDVR2... | Answered on Sep 18, 2009
I bet you $120.00 you did not have a 1000VA UPS on it. If I was right, you can pay me now, and I can send you one.
You need a new DTV.....or it will cost you $150.00 to fix.
The thinner they are the faster they blow...by the way they have a computer in there. You are luck you did not loose other stuff.
www.storminprotection.com
Hughes HDVR2... | Answered on Sep 11, 2009
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Hughes HDVR2... | Answered on Mar 26, 2009
I had the vary same problem, One solution is to remove the s-cable and use the analog video out, I have read lots of forums about this, it works for most people, No one seems to know why the s-cable causes pixelation on sat 2 input, and can't find anybody that can fix it completly, check forums at weak knees.com and tivo comunity. Good luck. ddftoc.
Hughes HDVR2... | Answered on Feb 24, 2009
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
Hughes HDVR2... | Answered on Jan 10, 2008
The pausing can be a sign that the DVR is having memory allocation problems. These are software issues and cannot be repaired, look for a software update to your unit. In addition if it is a hardare issue I would check the signal into the unit because when the picture freeze it could be due to a drop in signal. Now if these two are not the cause there is a third possibility, and that is a defective hard drive or memory storage device and its associative circuitry in the unit. I would suggest that you either have this unit replaced by the company that supplied it or take it to a qualified repair center.
Hughes HDVR2... | Answered on Sep 16, 2007
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily...
http://electro-medical.blogspot.com/
Hughes Televison... | Answered on Nov 19, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Hughes Televison... | Answered on Mar 18, 2015
Try ebay; if not there keep trying - sooner or later someone out there will have one for sale. Just be patient and enjoy the exercise till you get the replacement!
Hughes Televison... | Answered on Feb 23, 2014
check first the main power supply which is AC line get the voltage reading.if it is right check the plug of your Hughes HTL-HD receiver so if the problem is still going on, check the power supply section.
Hughes Televison... | Answered on Aug 25, 2010
you can get the manual here for the remote. It starts on chapter 8 or page 55
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_HIRD-E6.pdf
Good Luck
Hughes Televison... | Answered on Nov 06, 2009
Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver Logo
Popular Tags
13 questions posted
Top Hughes Televison & Video Experts
Tom Chichester
anabel smith
anabel smith
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hughes Televison & Video
Most Popular Question
huges hdvr2 work new directv hd service
  • Televison & Video
