Play Inc Fisher Price Music Play and Microphone Logo
Posted on Mar 05, 2011
The screen is flasing an exclamation point and reset won't fix the problem
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
7033
Points
8
I found this on another post:
"I had a error close to that one. It was a picture of the player with a flashing exclaimation. I couldn't do anything with the player. It was frozen. I plugged it into the computer and no results. I changed the batterys and got no results. I found the software and hooked it up to the computer again. It said there was a software update. I followed the prompts and it worked. The music player was back to normal. So those of you that have this player MAKE SURE YOU HAVE THE SOFTWARE!!!"
After reading the post, I went to www.fisher-price.com/kidtough/ re-downloaded the software and installed/launched it but didn't get any updates. So I disconnected the player but left the Fisher-Price software running in the background and started doing other stuff. When I went to shut down my computer, I was about to shut down the Fisher-Price software when I noticed the message prompt "THERE IS AN UPDATE TO THE SOFTWARE, WOULD YOU LIKE TO DOWNLOAD IT" I was so excited to see the prompt and I hit OK. It told me to connect the player to the computer before starting so I did and it automatically did an update. It appears to be working now! Sure hope this doesn't happen again!
tip
GARMIN WON’T TURN ON WHEN PLUGGED IN [FIXED]
Garmin GPS is an integral asset particularly when you are passing through another territory. Be that as it may, the gadget won't be useful in the event that it isn't controlled on.
As revealed by numerous clients, Garmin won't transform on regardless of whether its connected to the power supply. This can be very irritating be that as it may, settling it's anything but an incomprehensible assignment. Use garmin map updates free download 2019.
More often than not, a hard reset can fix the blunder. In any case, in some cases, resetting Garmin Nuvi doesn't work. In such a condition, how to control up your GPS?
Try not to stress, here, we will portray some simple approaches to dispose of the glitch.
What to do if the Garmin won't Turn on?
In the event that, you are managing this circumstance where Garmin GPS won't turn on, have a look at the remainder of the substance. Experience the accompanying fixes and apply them so as to turn on your Garmin Nuvi.
Arrangement 1-Check the Power
We should begin with a simple arrangement. From the outset, we propose you check the power association, as this can prompt this bug.
Along these lines, from the outset, plug the gadget with its unique Garmin charging link. Guarantee that there is no blockage between the charger link and the vehicle's electrical plug.
This incorporates other charging embellishments or splitter. You are unequivocally prompted not to utilize a blemished USB link. Rather, supplant it with another link and turn the vehicle's capacity on.
Presently, check the finish of the power link and ensure that the lights are on. On the off chance that, the power link doesn't illuminates, you should attempt an alternate vehicle.
Additionally, attempt to drive typically with Garmin GPS associated with control for quite a while (in any event 10 minutes).
We trust, this will fix the glitch. On the off chance that not, at that point don't stress, as we have given more than one arrangement.
Arrangement 2-Perform a Hard Reset
As said before, a hard reset may fix the blunder. Indeed, in the event that you don't have any thought regarding the resetting procedure, at that point here it is.
How to Perform a Hard Reset?
To start with, you need to detach the Garmin GPS gadget from the power source. From that point onward, go to the touchscreen and find the Reset choice. Press just as hold this catch on the lower right-hand corner of the screen.
Presently, turn on the GPS gadget and continue squeezing the lower right-hand partition. Sit tight for some time until you see a message saying 'Delete all information?'. In this way, click on the 'Yes' button.
A short time later, adhere to the on-screen guidelines to finish the hard reset system. At that point, check the status of the imperfection.
on Dec 17, 2019 • Sonocaddie GPS
Why does my tracphone have a red exclamation on the home screen?
What does it mean when my samsung tracfone shows a ...
www.askmefast.com/What_does_it_mean_when_my_samsung_tracfone...
What does it mean to have a icon appear on my samsung flip phone with icon little phone with ..... A symbol of a phone and exclamation point on my tracfone screen .... "The main screen that looks like a telephone with a red explanation mark.
Phone symbol W/ RED exclamation point? - BlackBerry Forums at ...
forums.crackberry.com > BlackBerry 10 Phones & OS > BlackBerry Z10
May 18, 2013 - 8 posts - ‎5 authors Now that I wanna take a screen shot of it it goes away. But your answers ... Red exclamation point next to e-mail on curve. By jr369 in forum ...
Exclamation LG 840G Tracfone/Safelink help! - Howard Forums
www.howardforums.com > ... > Tracfone/Net10
Aug 17, 2013 - 15 posts - ‎7 authors From the main screen, press the "Applications" icon at the bottom right of the ... i havethe same phone, can the lg840g be used with safelink?
There is a red exclamation point on the camera screen that won't go away. What is the problem?
Just got one of these cameras from a charity shop and after only a short use same problem.
Try connecting camera to PC as an external drive and delete (all) files..... This, too, may not work, in which case reformat the whole drive representing the camera - quick format will probably do.
Once you take a photo the directory path: DCIM/100IMAGE will be recreated.
I'd recommend reformatting quite regularly - after each time you download the photos off the camera.
McAfee icon with red square and exclamation point on my imac won't go away
http://mcafee-virusscan-uninstaller.en.softonic.com/mac
This will help you fully remove McAfee for reinstall or replacement.
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
6helpful
My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
6helpful
I touched the wrong pattern on screen,to unlock my security screen lock....and how to fixed this problem
you probably need to do a hard reset, which will unfortunately, restore your phone to the factory defaults.
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Just like new.
Oct 13, 2009 • HTC G1
1helpful
HP P2015DN
If just the triangle with the exclamation point in it is flashing, the printer is sensing the cartridge door is open
Top Play Inc Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Play Inc Toy Expert? Answer questions, earn points and help others
