20 Most Recent HP LaserJet P2015n Printer Questions & Answers
1. Check the toner level, when it's low the quality of the prints becomes poor.
2. If toner level is good, clean out the printer inside. The best way is to buy an air compressed can, get the printer in an open space and blow any toner from the inside of the printer. Give it a good clean as there might be residual toner inside that make the poor quality.
HP LaserJet... | Answered on Nov 10, 2015
contact your service provide for assistance on how to set it up
HP LaserJet... | Answered on Apr 28, 2015
heat main chip of formatter
HP LaserJet... | Answered on Mar 05, 2015
Go To Below official HP Printer Page For Your problem, Clearing Paper Jam Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
HP LaserJet... | Answered on Mar 06, 2014
insatall the 64 bit driver on the 64 bit pc then when asked if its local or networke choose Local set the bottom most drop down menu to standard tcp connection click next then in the address/location box type the IP address in manually
click next and finish installation job done
( your not sharing the printer to the 64 bit system - your installing the driver and allowing the Pc to share its connection with 32 bit systems)
HP LaserJet... | Answered on Jan 21, 2014
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer connects to the PC.
(4)Open the Front / Back Door of the printer and take a blower and clean any dirt inside. This will remove all the small paper particles that causes paper jam.
5) Now, reconnect the USB/Serial cable and switch ON the PC (only PC and not the printer).
6) Let the PC boot up and login to windows.
7) Now, switch on the printer, PC should detect the printer automatically now.
HP LaserJet... | Answered on Dec 29, 2011
Hello and Welcome to FixYa!
Sir, This problem is usually occur sometimes, First of all Turn Off the Printer and change the USB Port of the printer cable, Connect it in other USB Port and then Turn On the Printer, Now try i hope it works but if problem still exist then surely it will be problem of driver, May be some files are getting miss, Try to re install the Driver of your printer, This problem will surely be solved.
I hope you have clear picture in your mind, Don't hesitate to let me know if you have some confusion
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
HP LaserJet... | Answered on Nov 29, 2011
To configure this model HP Laser as a network printer, please click on this link and follow my instructions ;-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
HP LaserJet... | Answered on May 19, 2011
1, Go to your services and restart Print spooler (start-run-services.msc) start stop it 2. Reinstall printer driver 3. Check your network or USB cable (depends how you have conected it)
Best regards
HP LaserJet... | Answered on Mar 01, 2011
on this page:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1845558&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1845551
select your operating system and go.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
HP LaserJet... | Answered on Feb 25, 2011
Duplex printing on this printer is manual. You can download a user-guide from the address below (duplex bit is on page 42)
HP download page
HP LaserJet... | Answered on Feb 24, 2011
check your power cable, may be it did not connected properly
The Cartridge of this printer needs Drum /Dr. blade change ,so get it replaced.
HP LaserJet... | Answered on Feb 16, 2011
it may be the print head and if you go onto the HP website they have a chat feature that you can use to chat with someone to trouble shoot.
HP LaserJet... | Answered on Dec 09, 2010
try cleaning the pick-up roller.. or replace it with new one
HP LaserJet P2015n Printer Logo
67 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
need hp laserjet p2015 drivers windows 7
  • Office Equipment & Supplies
