The Learning Company ClueFinders 3rd Grade Adventures: Mystery of Mathra (381579) for PC, Mac Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will this work on a Windows Vista machine? - The Learning Company ClueFinders 3rd Grade Adventures: Mystery of Mathra (381579) for PC, Mac
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
Helped
32671
Points
344
Hello, the link bellow will show you all of the compatible windows version that can use this software http://www3.shopping.com/The-Learning-Company-ClueFinders-3rd-Grade-Adventures-Mystery-of-Mathra-Full-Version-PC-Mac-381477/info Thanks for using Fixya
  • Emily Read
    Emily Read Feb 05, 2018
    That just takes you to a website to buy it NOT show what computer compatible with this game you are a LIAR!!!!!!
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
tip
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA With three different...
With three different versions of Windows being used now, you’ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines.
In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version).
Set Windows 7 Share Settings
On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter.
Then click on Change advanced sharing settings…
Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles.
Depending on your setup, you might want to turn off password protected sharing. Other wise you’ll need to enter the password for each machine in, which isn’t that big of a deal. Turning it off while you’re setting it up makes things a bit easier though by saving a step.
Set Vista Share Settings
On the Vista machine we need to double check and make sure it’s sharing settings are ready to go. Right-click on Network and choose Properties.
The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery.
Also on the Vista machine you might want to turn off password protected sharing … but it’s completely up to you.
Share Files Windows 7 View
Now that we have the correct Settings On each machine, it’s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC.
There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared.
Share Files Vista View
Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it’s MYSTICGEEK-PC).
I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting.
Then you’ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available.
And you can continue browsing through all available shared folders and files.
Printer Sharing
As we showed above, you can see the printer connected to Windows 7. Let’s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter.
Right-click on the shared printer and select Properties.
Under the General tab click on the Print Test Page button.
The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine.
Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer.
Provided everything prints out successfully you might want to make it the default printer.
Troubleshooting
If your machines aren’t able to see each other or the printer isn’t working…here are a few steps you might want to use to determine where the problem is.
Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above.
In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer…
If the printer isn’t working, double check to make sure you have the latest drivers for each OS installed.
on May 24, 2010 • Computers & Internet
Unable to load 3d embroidery on hp windows 7 . Ihave a designer 1 sewing machine
3D was intended to be used on XP and also worked for some time on Vista with the proper manipulation of updates. I don't believe that it will work at all on Windows 7.
4D does work on both Vista and Windows 7. It does need the latest update for Windows 7.
WINDOWS XP & VISTA drivers
Yes you can dual boot any computer with vista and winxp.
Also you can user your web cam with winxp and vista.
Soft ware not combatable with windows vista. Help
Yup, if you mean Customizer 2000 when you say "software."
You can go to Janome's website and poke around for it (just so's you can see the neat stuff people are making -- always nice!) or just pop over to this link and download the newest update .
It'll make your MC and your Vista compie friends again. :)
Best of luck to you!
1helpful
Cannot find my flash drive in "diskpart"
If you have access to a Vista machine, try copying the dispart executable from that machine to your machine. This works in case of msconfig for Windows 2000.
Haven't tested, but may work.
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Adobe Photo Deluxe 2.0 will not work with Vista
yes
if your machine is 64-bit Vista, then you need to install Windows XP-64bit.
you can install Windows 32-bit on a 64-bit machine, it will work. just not as good. However, you can't install 64-bit OS on a 32-bit machine.
if the machine is 32-bit then you can install any type of OS you want, you can even install them as dual boot.
1helpful
I want to download free window vista software and let my laptop work faster
Get Vista here..
http://www.microsoft.com/windows/windows-vista/get/default.aspx
I would advise checking with the upgrade advisor before just installing Windows Vista - many older machines will not benefit from it.
http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx
4helpful
4answers
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
Top The Learning Company Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
